Please Help with my carburator! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2004, 06:32 PM   #1 (permalink)
locomike's Avatar
View locomike's Photo Gallery
I have a 1982 3TC engine, corolla that when I start it I get alot of GAS SMELL on the exhaust, and the engine shakes a little, when the car warms up to normal temp, everything works normal, Sometimes I get some "gas smoke" comming out of the exhaust, not oil smoke. If anytone can help me I would appreciate it. THANK YOU!
locomike is offline   Reply With Quote
Old 12-15-2004, 06:42 PM   #2 (permalink)
View automatic's Photo Gallery
This may sound strange, but you should make sure the ignition(plugs, wires, cap, rotor) is all in top shape before attempting to do anything with the carb.
automatic is offline   Reply With Quote
Old 12-15-2004, 06:49 PM   #3 (permalink)
View deekay140's Photo Gallery
Chk this link, its easier than me typing it again. 86 SR5 carburator problem
deekay140 is offline   Reply With Quote
Old 12-15-2004, 08:57 PM   #4 (permalink)
old fart
View el niño's Photo Gallery
I dealt with a similar problem with a 3f engine on a fj60, the mixture set screw at the base of the carb had moved, throwing everything out of whack, to adjust it properly screw it in all the way and go back 2 1/2 turns, that will bring really close to the ideal mixture, this screw is most of the times at the base of the carb facing the manifold, try that, see if it fixes your problem.
does keeping your foot down count as forced induction?
el niño is offline   Reply With Quote
Old 12-15-2004, 09:45 PM   #5 (permalink)
locomike's Avatar
I already did a full tune up, I will check that screw on the side of the manifold tomorrow. thanks
Old 12-15-2004, 10:27 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
be shure the choke flap pops open a little when the motor starts
Old 12-16-2004, 08:45 PM   #7 (permalink)
locomike's Avatar
flap closes in the morning, and after it warms up it opens, might this be the problem?
Old 12-16-2004, 08:46 PM   #8 (permalink)
locomike's Avatar
I didnt mess with the srew because I dont know if it will permanently discombinate it.
Old 12-16-2004, 09:04 PM   #9 (permalink)
old fart
that's the carb choke flap, it closes when the engine is cold and opens back up when it warms up, it decreases the amount of air going in the engine so it warms up quicker with a richer mixture, the screw I'm talking about is not in the manifold itself, it's on the base of the carburetor, and is the only thing that regulates the amount of fuel going in the engine, like I said, screw it all the way, and back out 2 1/2 turns, you will be able to tell it runs right by the change in pitch when the engine idles.
Old 12-16-2004, 10:17 PM   #10 (permalink)
locomike's Avatar
I will try that tomorrow, Idid see a screw like a flat head. I will try that strategy tomorrow. Thank you
Old 12-18-2004, 05:04 PM   #11 (permalink)
I always try and count how far I'm turning adjustment screws, that way I can put it back where it was if needed.
Also, if you try any adjustment to the choke flap, go easy,it's pretty sensitive.
