hey dude,
had the same problem with my AE102 93 corolla. this past weekend, i decided to pull the tank. everything was coming out ok, exhaust, shield, then i started undoing hte lines, the filer line, return line, then the vent lines. when i hit that, i got hit in the eye with gas ,then the mouth. found my leak, a crack in the tank. it was on the bottom side. when you get yur car up on hte lift or jack stands like me, look for a trail. when the gas leaks it leaves a varnish trail. should point you back to where the leak is. to fix mine, i used some permatex 2 part epoxy gas proof sealer. clean well and follow directions. i had to put the vent lines back on to stop the gas from dripping(stopping gravity and causing a vaccume again in the tank), but i 2 hours(takes that long to harden) the leak was gone. i asked a freind of mine and he said it is very common for 93-97 corollas. they changed several ath the delaership he works at. and i peaked under my coworkers corolla yesterday and saw he had a leak too...
god luck... hopefully you won't have to buy a new tank.
