AE86 Clutch fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2004, 03:15 PM   #1 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
AE86 Clutch fluid?
'k, so at some point, i think my slave cylinder might have given out. Now, I'm low on fluid. What kind of fluid am I supposed to use?
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 12-21-2004, 03:18 PM   #2 (permalink)
View micro214_kp61's Photo Gallery
brake fluid!
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 12-21-2004, 03:20 PM   #3 (permalink)
4Aaron GE's Avatar
Thanks, man. Any particular type?
Old 12-21-2004, 03:35 PM   #4 (permalink)
View hachi_slow's Photo Gallery
Dot 3 should be good enough.
hachi_slow is offline   Reply With Quote
Old 12-21-2004, 07:56 PM   #5 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
Yep. Dot 3 brake fluid.
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
Old 12-21-2004, 10:02 PM   #6 (permalink)
4Aaron GE's Avatar
'k. thanks guys. now to figure out how to get to Crappy Tire in -20 degree weather. bleah....
Old 12-22-2004, 12:32 AM   #7 (permalink)
Gameroom cash: $134355
i use high temp dot 3 or dot 4 fluid for my brakes and clutch lines..... it's meant for ABS systems.... harder to break down
Old 12-22-2004, 09:55 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
ABS and non abs brakefluids arent different, they dont break down either. they absorb moisture.
Old 12-23-2004, 10:43 AM   #9 (permalink)
4Aaron GE's Avatar
Hey guys? Just to verify, ALL Kouki clutch masters are the same, right?
Old 12-23-2004, 12:12 PM   #10 (permalink)
Aaron.. if i'm not mistaken ALL AE86 are the same.
Old 12-23-2004, 12:29 PM   #11 (permalink)
View ratboycom's Photo Gallery
nearly all toyota clutch slave cylinders are the same some have different drain positions or slightly longer push rods but that is about it
ratboycom is offline   Reply With Quote
Old 12-23-2004, 01:09 PM   #12 (permalink)
4Aaron GE's Avatar
Actually, there was a redesign of the part between zenki and kouki. The place where I"m getting the parts from only lists to 1986.5 My car was produced in April 87.
Old 12-23-2004, 01:42 PM   #13 (permalink)
There's a significant difference btw the clutch mc's from zenki and kouki externally. You'll be able to tell if they're selling the part that you need just by looking at them. Go to Migs' site dreamsofdrifting.com and there are pics of both zenki and kouki cmcs.
Old 12-24-2004, 10:27 AM   #14 (permalink)
there is a difference between the master cylinders but the slave cylinders are pretty similar
