You probably had those crappy Goodyear Integritys as I did on mine that lasted only 35K. You can't be getting any more snow/ice in Mass then I get in the Cleveland area. I checked reviews on line and found a great tire that is affordable. I went to a BFgoodrich(made by Michelin now) Traction T/A H rated. I went to Sams club they had a special $15 off each BFgoodrich tire and got a set with taxes--lifetime balance, rotating, road hazard for $310... I went to a 205-65-15(my rolla s called for a 185-195) because it had an extra tread on it...they fit/ride great, just tried them out in the snow/ice for the first time Sunday with not a problem plus they have grooved sides for better cornering, if you would live in Canada then I would suggest winter tires, also if you want to spend the money there are plenty nice tires out there, but I'm very happy with these
...If you do buy these they are a directional tire make sure they are put on with the arrow going forward...hope this helps....Raddman
http://www.tirerack.com/tires/surve...y.jsp?type=HPAS
"THE FIRST MOUSE GETS THE CHEESE"
