idle speed adjustment on 20V ST - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2004, 05:57 AM   #1 (permalink)
PeopleSoft Tech
badtoy's Avatar
View badtoy's Photo Gallery
Hello,
just had a successful transplant about a month ago with a 20V silvertop on my AE92 sedan. Everything is working fine now except for a small minor problem. My idle rev is too high, its about 1.7K RPM
I had all possible causes checked like
- ECU: i thought my ECU was faulty but when I plugged in another ECU I still have that high RPM on idle speed. Tested also my ECU on another 20V engine and works fine.
- vacuum hoses: checked everything, I might have left a hose open but all is well.
- thermostat/ temp sensor: working fine also
do you think its just an adjustment on the Idle speed controller? where can I adjust this?
badtoy is offline   Reply With Quote
Old 12-24-2004, 12:58 PM   #2 (permalink)
Immortal
View Kwanza's Photo Gallery
Check the TPS, AFM, and timing.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 12-24-2004, 10:16 PM   #3 (permalink)
View micro214_kp61's Photo Gallery
hey Mike.. welcome to TN!
check the AFM, someone told me that if it was angled a bit off, it won't idle properly. also check the TPS like Kwanza said.
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 12-25-2004, 06:58 AM   #4 (permalink)
PeopleSoft Tech
badtoy's Avatar
ey mike... thanks,
i'll just have my car brought to the shop to have the throttle body clean and do some adjustments on the TPS and timing
Old 12-25-2004, 08:53 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Not sure if the 20V would have one, as I've never dealt with a 20V in person. But have you tried the idle screw?? I know the Bigport 16V's have it right where the intake port would be, its covered by a black rubber cover. With my car I've noticed that if I raise the idle leave it for a bit, then lower it to where I want it, it will idle always at that setting.
Old 01-16-2005, 10:35 PM   #6 (permalink)
View surfa's Photo Gallery
Hi,
I have a similar problem. I got a 1988 corolla with a 4A-FE engine in it.
I had the starter motor replaced by a mobile mechnic about a week ago. I saw some sparks came out near the starter moter during the replacement. Possibly the positive wire of the starter had short circuit with the body.
Initally it was ok. But after a few days, the idle speed suddenly gone to 2100rpm even after the engine warm-up.
Any one may know if shorting the positive wire of the starter motor to the car body may cause any damage to ECU?
Will the engine faulty light comes on if the ECU is damaged.
Any helps are very appreciated.
surfa is offline   Reply With Quote
Old 01-18-2005, 10:58 AM   #7 (permalink)
View MississaugaGTS's Photo Gallery
Surfa....
I don't think the shorting would affect the ECU as the engine is grounded directly to the battery and body, therefore there is no route for current to flow through the ECU. The only way this may have damaged the ECU is if the short was on a sensor ground wire or something of that nature.
MississaugaGTS
MississaugaGTS is offline   Reply With Quote
