engine or tranny problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2004, 03:26 PM   #1 (permalink)
View ohhenrygs's Photo Gallery
The info on the Toyota goes as follows 1989 Toyota Corolla SR5 1.6L 3 speed overdrive plus manual overdrive carbureted. The problem goes as follows; at around 60kms the car starts to "buck" like not getting fuel. Then once past that stage it starts to rev up but speed does not really increase. The other day the problem got worse, as I was stuck in a parking lot and with just the rocking of the car from D to R to get unstuck the car kept staling, making me believe the problem is fuel related. All problem seem to be when the car is put under load. However the car starts and idles fine. please help
ohhenrygs is offline   Reply With Quote
Old 12-29-2004, 03:31 PM   #2 (permalink)
Gameroom cash: $147537
Check ignition components. Could be bad coil. Unless you don't have enough tranny oil or broken torque convertor.
Old 12-29-2004, 07:57 PM   #3 (permalink)
are there any other ways to check for this problem?>?
Old 12-30-2004, 12:29 PM   #4 (permalink)
View Hemi3TC's Photo Gallery
Along the lines of ignition, check the vacuum advance. If the vacuum advance is leaking air gets sucked into the intake manifold or carb depending where it is hooked up. this causes a lean surge and the loss of some ignition advance will be reduced power.
hemi3TC
Hemi3TC is offline   Reply With Quote
Old 12-30-2004, 01:24 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That sounds more like a fuel problem to me.. does the car stall? I used to have an old carb'd civic, but it was 5spd. It used to do the exact same thing, turns out the fuel filter was so clogged that eventually it just gave up and fuel started to gush out. After the filter was changed the car ran even better.
If the filter doesn't change anything, then chances are the fuel pump needs to be replaced.
Old 01-03-2005, 02:13 AM   #6 (permalink)
View bluedemon's Photo Gallery
wrong wrong............what i think is your tranny filter is clog.....maybe im wrong .buy this happen to me before i could be wrong tho....replace it with a new filter
bluedemon is offline   Reply With Quote
Old 01-03-2005, 02:29 AM   #7 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Check the tranny fluid.
It's probably years past time for being flushed, and more than likely is somewhat low.
AIM/Yahoo Toysrme257th
Now with Turbo!
