Well.. to start, an AE110 is FWD, you would have to source out a RWD transmission that would match the 3SGE/GTE powerplant, I don't think the 3S ever came in RWD, so you might be out of luck on that one. If you were staying with FWD you could use a Camry transmission(not sure what the transmission code is).
Second, you would have to source out parts from a RWD Toyota in order to convert your car to RWD, you're looking at suspension parts, driveshaft, etc.. you could take these parts from a Supra, but then you're looking at a lot of money after you're done.
I'm not saying this swap is impossible, it would just be expensive.. proving you can find a suitable RWD transmission for a 3S motor. My advice, stay with FWD.. the swap is expensive enough as it is.. RWD would just kill it.
