Keyless entry remote - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2004, 03:01 PM   #1 (permalink)
View mclee45's Photo Gallery
anyone have instructions on how to program OEM remotes for the keyless entry for a 99 corolla?
mclee45 is offline   Reply With Quote
Old 12-30-2004, 03:36 PM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
I have TSB AX005-99 "Toyota VIP RS3000 Programming" It is 4 pages PM with E-Mail and I will scan them and get them to you.
Also let me know if want JPEG or PDF format.
CraigW is offline   Reply With Quote
Old 01-01-2005, 09:36 AM   #3 (permalink)
Does anyone know the actual location of the Alarm ECU unit in the 98-02 generation Corollas ??and also the location of the module that contains the glass breakage sensitivity adjustment ??
The TSB I have shows it under the drivers seat but neither the OP or I can locate the unit, The alarm users guide does not point out the location of either unit.
Thank You,
Old 01-05-2005, 12:13 AM   #4 (permalink)
Craig, the shock sensor is under the driver dash. look from under the dash and you can see it stuck on the firewall. you can adjust it without removing it. Its just above the brake pedal. You find that F$$king alarm ecu yet?
Old 01-05-2005, 05:50 AM   #5 (permalink)
Wait a minute !! I pulled the center console on my 00 and found the shock sensor there, (has the trim-pot adjustment for sensitivity)
Maybe you are seeing the alarm ECU near brake pedal ? I will look at mine today. I did a pretty good search and did not locate the ECU. There could be slight changes from the 2 years ??
Old 01-05-2005, 03:52 PM   #6 (permalink)
it definitely is the shock sensor and adjustment because i can see the adjustment knob just by looking at it. Its the freakin ecu i cant find.
