OK 2 simple tests here, get a couple buddies and some rags, get in the car and put it in 1st gear, motor off and hold the clutch down, they should be able to push the car, now let the clutch out while still in 1st, they should not be able to push the car, then pop the hood and get your bigger buddy to get the rags and grab the fan belt, pull the e brake up hard and put it in 1st gear, push the clutch in and see if he can turn the motor over, he should be able to, now let the clutch out, now he should not be able to turn it, now take it out of gear, now he should be able to turn the motor and it wont matter if the clutch is pushed or not. These tests will verify or eliminate something in the trans locked up
