Thanks halforc, The rotor does point to #1. The loobs are in the right place as well as the outer gear. It just seems the crank gear is off, The piston is at the very top and the pully mark is on the zero. I still have yet to check the crank gear alignment w/ the oil pump housing to see if it the same as the pully mark on the zero for TDC.
I don't work on cars for a living, but I am no stranger to swinging a wrench. I have had a few toyotas, change t belts in other makes and do my own work on everything. I just need to put in more time in to figure it out. Thanks for your suggestion.
