7a-ge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2005, 07:56 PM   #1 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
7a-ge
Hey. I have a 7A-FE in my 95 Corolla. I've been reading corollaperformance.com again, and I'm really interested in making it into a 7A-GE.
I'm wondering where I could get Toyota's G heads. Probably I would have to go to a junkyard and get then out of a 4A-GE. Anywhere I could buy them new?
Anyway I was also wondering how much work this would be. I have no experience taking out or taking apart engines, so I'm wondering if I could do it with some tools and a Haynes repair manual. Or is it too difficult a job for me to attempt?
Also, how much would fuel economy decrease and how much hp/tq would I gain with this mod?
Any input is greatly appreciated.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 01-07-2005, 08:05 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
just get one from a junkyard... finding one new, well you could ask toyota, but... that would be big bucks.
Old 01-07-2005, 08:19 PM   #3 (permalink)
Gameroom cash: $147537
It more then cut and paste. How good you're with wiring? You'll need ECU and other sensors from the 4A-GE. Just swap a 4A-GE.
Old 01-07-2005, 08:19 PM   #4 (permalink)
Immortal
View Kwanza's Photo Gallery
If you've never taken apart an engine... this project may not be the best start because there is a degree of wiring involved, along with parts swapping. A haynes manual isn't gonna help you much either... It's not extremely difficult... but you wanna learn things and see watch the steps before you simply jump in.
I have a 4AGE head I can sell BTW, but you'll need more than that.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 01-07-2005, 09:33 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
better off getting a entire 4age motor, manifolds and all
Old 01-07-2005, 09:52 PM   #6 (permalink)
Ghostridin the whip
Aright I think I'll pass on this for now. Thanks for the info.
Btw, a 4A-GE would be a lot less torque than a 7A-GE.
Old 01-07-2005, 10:40 PM   #7 (permalink)
View Jake25's Photo Gallery
you'll need 4age belts
and a porsche 924 pulley
or is it the other way around.
Jake25 is offline   Reply With Quote
Old 01-07-2005, 11:48 PM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
the valve reliefs on the pistons are different also, G heads have a wider valve angle therefore making the edge of the valves go deeper into the cylinders. The pistons may hit them.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 01-08-2005, 12:18 AM   #9 (permalink)
Generic user title...
View xiao_sq's Photo Gallery
this will help a bit ^______^ http://www.club4ag.com/faq%20and%20t...20and%207A.htm
xiao_sq is offline   Reply With Quote
Old 01-08-2005, 12:47 AM   #10 (permalink)
I think its the opposite. Wide valve angle creat a higher chamber which the valve won't go as deep and has lower CR with the dished piston on the 7A-FE.
Old 01-08-2005, 03:07 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
as far as I know, the pistons will hit the valves.
Old 01-08-2005, 09:41 AM   #12 (permalink)
View micro214_kp61's Photo Gallery
nope.. it's the other way around. Porsche 924 timing belt and 4A-GE pulley!
another option is GATES timing belt.... T111-116 teeth, T107-117 teeth, T140-118 teeth
Ukrainian102... what i heard is that tuning would be hard to maximize the power of the said hybrid. the 7A-FE bottom end might not be strong to rev high enough that it can go with the high revving parts of the 4A-GE head. you have to figure out how to make the bottom end capable to rev like your head. i hope i didn't confuse you more.. hehehe
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 01-08-2005, 01:05 PM   #13 (permalink)
sure the torque in the 7A-GE Will be more, it was build for torque
but the 4AGE will for surpass it in HP...
Old 01-08-2005, 02:01 PM   #14 (permalink)
Immortal
Nope... pineapple is right... the 7AFE pistons are dished and the compression chamber size in the 4AGE head is significantly larger. There will be a compression loss and the valves won't hit.
Old 01-08-2005, 02:05 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
Have you tested it? Because the 4A-GE pistons have cuts in them for the valves, as the valves are at a larger angle, thats the problem and thats why they would hit.
