Originally Posted by JasonH
I don't know which transmission you're talking about but L means "low" or more specifically "1" or first gear. If the car is moving too fast to shift into first gear (say if you're going 70) then it will shift into second until it can shift into first.
Jason
Is that true even for the older Toyotas?
Anyway, L means it won't go above first gear, 2 means it won't go above second gear, D with O/D off means it won't go above third gear, and D with O/D on means it'll use all the gears.
