AE92 Brakes... Does it seem to be a problem ??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2005, 12:00 PM   #1 (permalink)
View keremerdag's Photo Gallery
Hi,
I have an AE92 with 4AF engine. The brakes seems to have a problem. When I push the pedal, it brakes enugh to stop the car but vey difficult to lock the wheels. After about 8 - 10 pomps on the brake pedal, it brakes much more better and it can lock the wheels easily.
Does this seem to be a problem? If yes, how can it be solved?
Thnx for help.....
keremerdag is offline   Reply With Quote
Old 01-09-2005, 03:06 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
yes it does seem like a problem ...... check your brakes .... you should have drum in the back so try and make sure they are tight enought ..... i heard reverse with the parking break on helps tighten them up ....
^ and leaving it that way!
Old 01-09-2005, 05:02 PM   #3 (permalink)
all brakes seem to be in good condition. can it be because of the westinghouse?
Old 01-09-2005, 05:34 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
what's a westinghouse?? I know its a brand of kitchen appliances.. but on a corolla?
Old 01-09-2005, 05:39 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Might be old brakefluid/air in the system.
Old 01-09-2005, 06:48 PM   #6 (permalink)
View automatic's Photo Gallery
I had a similar problem with my Lexus, had been abusing the brakes daily for a couple years. I flushed the old, funky brake fluid out and it works much better now.
automatic is offline   Reply With Quote
Old 01-10-2005, 03:48 AM   #7 (permalink)
In Turkey they call the brake centre "westinghouse". i thought it was the unique name....
i changed the brake fluid last year. in one year does it get old?
Old 01-10-2005, 05:58 AM   #8 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
might be the brake master... the rubber seals might be worn.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 01-10-2005, 09:49 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
If they used crappy / old fluid, it might.
Old 01-10-2005, 11:27 AM   #10 (permalink)
ok buddies... thnx for help.
Old 01-14-2005, 11:21 AM   #11 (permalink)
View 92CorollaWgn's Photo Gallery
I agree with changing the fluid first! When you're not sure always start with the least expensive possibility and work your way up. I will be doing my brakes on my AE92 wagon this weekend and changing my black fluid is on the agenda as well. By the way, if anyone needs very reasonable replacement parts try this link below. Shipping is free above $50 and the prices are the best I've seen. I bought new rotors, drums, front pads, and back shoes for like $125.......with free shipping!
http://www.mr-auto-parts.com/epcvsoa...=mr-auto-parts
92CorollaWgn is offline   Reply With Quote
Old 01-15-2005, 11:00 AM   #12 (permalink)
eg1800cc's Avatar
View eg1800cc's Photo Gallery
I definitively agree with the comment to start with the most easy things to diagnose and work your way up. In regards to a braking system, there are a few things that you need to consider that might make you pedal feel soft. First of all just as mentioned previously air in the hydraulic system or old, worne brake fluid. Second would be your pads being overly worn on an old caliper in which the cylinder is close to siezing. This will cause a longer pedal stroke as well and you should be able to regain some of your pedal feel after a few applications. The last thing would be the master cylinder. A M/C is designed with two separate hydraulic ports. If one of these ports fails, due to seal weare or contamination, the secondary port will allow you to still stop the vehicle but with increased effort (force on the pedal) as well as increased stroke. You should also regain some of the pedal feel after pumping the brake. Other considerations for soft brakes can be small cracks in brake lines, worn brake flex lines going to your calipers and loose or rusted fittings. You should check the whole system for leaks. Hope this little bit helps and good luck on your trouble shooting.
Rafal
No more JDM... pure DTM!!!
eg1800cc is offline   Reply With Quote
