Car not starting...again! '97 Corolla Automatic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2005, 08:03 PM   #1 (permalink)
View daren's Photo Gallery
Unhappy Car not starting...again! '97 Corolla Automatic
After spending $400 to replace the starter and burnt wires, the car ran fine for two weeks (see my previous thread). Then, it stopped starting.
I tried starting the car three days ago. Luckily, the starter works fine, but for some reason, the engine will not run.
I am pretty much completely lost on why this isn't working.
I did notice that as I first starting pumping the accelerator, that I accidently had the car's rug jammed on top of the accelerator overnight. I heard that that has no affect on the car whatsoever though.
The only option I can think of is taking the car back to the guy who replaced the starter & wires.
Any opinions or help? I would appreciate it very much.
-Daren
daren is offline   Reply With Quote
Old 01-12-2005, 08:30 PM   #2 (permalink)
View karugs's Photo Gallery
Alternator? Spark plugs?
karugs is offline   Reply With Quote
Old 01-12-2005, 08:36 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Check the wires to see if they're plugged in tight.. maybe he didn't put them on tight enough and you might not be getting a spark. Other than that, maybe the plugs are done now.. if the wires were dead, chances are the plugs might be gone now too.
Old 01-13-2005, 12:34 PM   #4 (permalink)
View Fmmc_jay's Photo Gallery
Ok I kinda had the same problem with my 96' and it turned out it was the 100watt fuse once that was replaced it started right up, this was caused when the positive and negative wires touched, or if you jump your car wrong it will happen
Good luck
James
Fmmc_jay is offline   Reply With Quote
Old 01-13-2005, 01:24 PM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
If the engine cranks over fast with a no start meaning not even hitting on one cylinder then it sounds like a loose ground wire somewhere it might be a wire loose/off on your ignition pk.....I did the same thing replacing an alternator and I accidentally knocked one of the wires loose.. but it wouldn't hurt to take a look at your fuses as Fmmc_jay said...
__________________________________________________ _________________________________
"HONK IF YOU HATE NOISE"
Raddman is offline   Reply With Quote
Old 01-13-2005, 08:10 PM   #6 (permalink)
View Merciles's Photo Gallery
omg i may have had the same problem you had before....
my car will start after a few tries, i believe the cold may have something to do with it but it's not that cold....
well all my lights and fans turn on but my engine doesn't crank....i hear the solenoid work but no crank. After a few times of trying it, it will all of the sudden work. Anyone have any ideas?
btw i have a 97 corolla automatic.
thx for any info
Merciles is offline   Reply With Quote
Old 01-13-2005, 08:34 PM   #7 (permalink)
KDM is in
REN69's Avatar
battery maybe.. sometimes the battery will have enough power to hold all the lights and instruments on.. but not enough amps to crank the motor.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 01-13-2005, 08:55 PM   #8 (permalink)
Registered User
Raddman's Avatar
USA
"well all my lights and fans turn on but my engine doesn't crank....i hear the solenoid work but no crank. After a few times of trying it, it will all of the sudden work. Anyone have any ideas?"
Starters going........ ...Raddman
__________________________________________________ ____________________________________E"DON'T LAUGH ITS PAID FOR"
Old 01-13-2005, 09:28 PM   #9 (permalink)
tried to jumper the car but didn't work so i don't think it is the battery..
Old 01-13-2005, 09:29 PM   #10 (permalink)
anyone have any idea how much it will cost to repair that?
Old 01-13-2005, 10:12 PM   #11 (permalink)
Registered User
Raddman's Avatar
USA
If your talking about the starter its about $150 at a shop and if you get one from the bone yard and put it on yourself your looking at about $35...only has two bolts on it but I don't know how hard it would be to get to on your model....a clicking solenoid and no crank with the battery being good will mean 95% of the time your starters almost shot...JMHO ...Raddman
"DRIVE IT LIKE YOU STOLD IT"
Old 01-13-2005, 10:15 PM   #12 (permalink)
thx much appreciated
