to replace the filter, its pretty easy. just plug the tank side (inlet) and disconnect the line from the filter. then plug the motor side (outlet) and disconnect that line. check the lines for cracks, frayed ends, all that good stuff. connect outlet then inlet and yer good to go! it really is that simple! pencils work great for plugging the lines by the way. It may come out with some pressure, so dont freak out, let the car sit overnight if you can to relieve some pressure and also to let the engine cool (gas is flammable dont forget, and a hot motor can cause "problems"!!!)
92 Corolla (d. 1997)
94 Corolla Wagon (d. 1998)
98 Corolla 140K Mi
99 Corolla 110K Mi
00 Corolla 80K Mi
03 Corolla 30K Mi
