Cruise control on an '88 Corolla possible? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2005, 12:10 AM   #1 (permalink)
View excelent3's Photo Gallery
I would like to ad cruise to my car, which is a 5 speed. I was told by a very reputeable aftermarket shop, that it could not be done. They checked with several suppliers, and they informed me, the main challenge was the accelerator linkage would have to be bent to install the cruise, which in turn could cause more challenges later....therefore they did not recommend it. BUMMER. I have done business with this outfit for 25 years, and they are even recommended by the Toyota dealer here locally.....
BUMMER,
Any ideas?
excelent3 is offline   Reply With Quote
Old 01-15-2005, 02:23 AM   #2 (permalink)
Will Work For Boost
View MrRavenX's Photo Gallery
My 87 Corolla FX16 GTS had cruise control and it was a 5-speed. Soooo... I'm sure it's do-able, you might have to visit a junkyard though and find the used parts.
Previous toys:
AE82 FX16 GTS 5sp JDM 4AGZE
MA61 P-Type 5sp
VZN170 5sp TRD SC
ZZE131 6sp
MrRavenX is offline   Reply With Quote
Old 01-15-2005, 04:57 AM   #3 (permalink)
View cobrajet25's Photo Gallery
Cruise is not limited to cars with automatics. There is an additional disruptor switch on the clutch pedal (like the one on the brake pedal) to disengage the cruise when the clutch is depressed, which keeps the engine from over-revving itself to death while the cruise is activated. If you want to use the factory setup, you need to find one in a yard that has cruise and a 5-speed. This will be tough, as most cars equipped with cruise control are LE models, and they tend to be automatics.
But there is another problem. The controls for the cruise are on the same switch as the wipers. I have never seen a car with cruise that did not have variable interval wipers (different setup than regular interval wipers found on other models). Because they use the same control stalk I think these two options may have been paired together exclusively, so if you add cruise you may have to change your wipers, too. One of the most annoying things about Corollas is the fact they are not prewired for all options or even just popular options like cruise, power windows, trunk lights, etc. If you want to install a factory cruise setup on a Corolla you have to wire it from scratch. Kind of a hassle...if you can't find anything aftermarket that will work it may be more trouble than it is worth. Regards, Aaron
cobrajet25 is offline   Reply With Quote
Old 01-15-2005, 07:59 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
88 Corolla what? GTS, SR5, LE? 2dr, 4dr? you're only saying your car is an 88 Corolla so it doesn't really help much. I doubt your car is a GTS though, my GTS came with cruise control and its a 5 speed, go to a wreckers and source out as many parts as you can from a GTS if you can.
What do you need cruise for? I never use mine, I've always considered it a lazy option.. I drive about 75Km to work and 75km back (bout 50Mi I'd say) and honestly don't see the need for it.. maybe if I was doing cross country or province driving, but still. Our speed limit on 400series highways in Ontario is 100kmh(60mph) but most people do roughly about 125kmh. I think maybe our highways are a little too busy for me to see any use of it, maybe at like 2-3am when there's no one on the road.
Old 01-15-2005, 02:00 PM   #5 (permalink)
More hassle than it's worth, I can live without it. I have a knee that gets stiff, like to stretch it out once in awhile, can't without cruise. I'll have to do ahand setup with a couple o pulleys!
Old 01-15-2005, 02:01 PM   #6 (permalink)
By the way, it's a base model. total plain jane, other than air ,and rear window defrost.
EX3
Old 01-15-2005, 09:20 PM   #7 (permalink)
Loud Street Machine!
View 89rolla's Photo Gallery
My AE-92 sedan which is 5 speed and is has a 4-AF motor has cruise control...so you should be able to just go to the jusnk yard and find the parts that you need to make it possible!
AE92=
89rolla is offline   Reply With Quote
Old 03-16-2007, 06:40 PM   #8 (permalink)
View tha_messenger's Photo Gallery
i have a 88 sr5, and mine has cruise
tha_messenger is offline   Reply With Quote
Old 03-16-2007, 09:22 PM   #9 (permalink)
KDM is in
REN69's Avatar
Helps to see this thread is 2yrs old dude.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
