Please help! Corolla Door problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2005, 01:23 PM   #1 (permalink)
View Bubbakanoosh's Photo Gallery
Hi, ive got a 93 corolla, and my rear passenger door will not stay shut. The lock mehanism will not stay locked. Also when i took a screwdriver and slid it into the mechanism, and then pulled the door handles, neither of them released the lock. is something disconnected? i removed the door panel but cannot see the problem. Thank you, i appreciate the help.
Bubbakanoosh is offline   Reply With Quote
Old 01-18-2005, 02:15 PM   #2 (permalink)
4A-GZE
KnightX_AE86's Avatar
View KnightX_AE86's Photo Gallery
is the rubber pice at on the door in the way???? play around with the door look... i dun thinkg u need to get inside the pannels
but i could b wrong
KnightX_AE86 is offline   Reply With Quote
Old 01-19-2005, 09:31 AM   #3 (permalink)
View karugs's Photo Gallery
You might need a new locking mechanism. Maybe just the latch part (the metal piece at the rear side of your door, where the small hook from the car attaches to). Or it could be as simple as a broken plastic part. Happens often.
karugs is offline   Reply With Quote
Old 01-31-2005, 01:56 PM   #4 (permalink)
View wjones139's Photo Gallery
I lubricated the mechanism with WD40 on my 2001 Corolla
It was cold and the viscosity of the grease was too high. I lubricated the mechanism with WD40 and the door would then close. I see you are in MA. It's cold there. Maybe same problem.
wjones139 is offline   Reply With Quote
Old 01-31-2005, 03:19 PM   #5 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
pretty much i have the same problem on mine...my door handles actually pops up and i think the clip is broken from the inside....
TRDXRS...
Corolla_reps is offline   Reply With Quote
