Do i have to lift the car or is it possible to change the oil without lifting it?
Also can i just use the one lift that is in the trunk or do i need to get more?
Where is the oil filter and drain plug located?
if you gotta ask those questions, then leave it to a professional to do it. there can be to many things that you can overlook and screw up.
But not to sound too cruel, no the jack isnt enough, the car has to be level, the drain plug is located on the passenger side of the oil pan, the oil filter is behind the manifold.
