Conducting Brake tests.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 01:33 AM   #1 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
Hi dudes..
Can any of you guys tell the procedure to conduct tests on Breaks..
I need to press breaks hard to stop my car.. Dont no what went wrong.. Is that the prob with break oil loss or with the cylinder.. ???
I appreciate your reply..
take care
celica2004 is offline   Reply With Quote
Old 01-22-2005, 01:34 AM   #2 (permalink)
celica2004's Avatar
my car is 1993 corolla ( 143K)
Old 01-22-2005, 08:38 AM   #3 (permalink)
View karugs's Photo Gallery
Hard to stomp on the pedal? I would suspect vacuum assist has broken. Check the system if you have vacuum leaks. I would also suspect the pads--if they're worn the car could be hard to stop too. Are the fluid levels correct?
karugs is offline   Reply With Quote
Old 02-07-2005, 04:46 PM   #4 (permalink)
Do I need another corolla
View osudrewski's Photo Gallery
Did you change the pads recently or do anythign weith the brake system? Check teh fluids, if low fill. If still have to slam the pedal, you will need to bleed the system if you opened any part of the system during a brake change.
92 Corolla (d. 1997)
94 Corolla Wagon (d. 1998)
98 Corolla 140K Mi
99 Corolla 110K Mi
00 Corolla 80K Mi
03 Corolla 30K Mi
osudrewski is offline   Reply With Quote
