Coolent Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2005, 10:53 AM   #1 (permalink)
celica2004's Avatar
View celica2004's Photo Gallery
Coolent Problem
Hi dudes,
I have a problem with coolent.. I filled coolent into my 1993 Corolla three days back and today I found that its below the low level.. I havent used my car from then...
Can any of you tell me the potential problems that might have caused this...
Are there any diagnostic information ...to locate the problems..??
Plz let me know if you know any thing about this ..
thanks..
James..
celica2004 is offline   Reply With Quote
Old 01-23-2005, 11:23 AM   #2 (permalink)
.....drifto time.....
View etxxz's Photo Gallery
obviously you are leaking coolAnt. To detect Where is leaking just look at the puddle that forms under the car, its probably your radiator...specially if its the original one ~ old
etxxz is offline   Reply With Quote
Old 01-23-2005, 11:35 AM   #3 (permalink)
View karugs's Photo Gallery
Or it could have just had some air pockets and the coolant wasn't enough to fill it up. Initially it looked full because of the said air pockets. I would top it off and if you find fresh coolant on the ground, THEN that's a leak. I would also check hoses for tightness, the radiator cap, and if you have, the heater hoses as well.
karugs is offline   Reply With Quote
Old 01-23-2005, 01:42 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
radiator cap, radiator, hoses, waterpump, the pipe at the back. those are few places to look.
Look around the head gasket.
Old 01-23-2005, 06:52 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
did you run your car after you filled up the coolant fluid?? because you're either leaking coolant into the motor or you got an external leak.. look for coolant puddles or coolant spots inside your engine bay.
Old 01-24-2005, 12:47 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Check your dipstick, if you can see oil traces on that, its gone into the oilpan
Old 01-24-2005, 05:17 AM   #7 (permalink)
View cobrajet25's Photo Gallery
I assume this is the same engine you are having compression problems with? You may have a leaking head gasket. A leaking head gasket could cause a loss of coolant AND low compression. Coolant is actually being burned by the engine during combustion and coming out the exhaust as steam. If there is no obvious leak, then this may be a possiblility. It is also possible that you just didn't fill it up enough. Fill it again and keep an eye on it. Good luck. Regards, Aaron
cobrajet25 is offline   Reply With Quote
