RETRIEVING CODES for vehicles before 96
NOTE: Not all trouble codes will activate MIL (CHECK ENGINE light) - Before proceeding, make sure the:
- CHECK ENGINE light circuit is functional. It should be ON when the ignition switch is ON with the engine stopped.
- Battery voltage is above 11 volts.
- Throttle valve is fully closed (Throttle Position Sensor IDL points closed).
- Accessory switches (A/C, etc.) are OFF.
- Engine is at normal operating temperature (if possible).
- Turn ignition switch to ON position.
- Do not start the engine.
- Place a jumper wire across TEl and El terminals in engine check connector.
- Count number of flashes from CHECK ENGINE light.
- If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
and evenly about 2 times a second.
- Otherwise, the light will blink a number of times equal to the trouble code as follows:
- The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
- The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
- If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
- Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
- The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected.
- When finished, remove the jumper wire.
- After repairing the malfunction, clear the codes from the ECUs memory.
Here are the words that I pulled off the net (
www.batauto.com) and here are the codes, later WD
Trouble Codes
Without Onboard Diagnostics (OBD-I)
1Normal Condition.
2Air Flow Meter signal.
3Ignition signal.
4Engine Coolant Temperature Sensor signal.
5Oxygen Sensor.
6RPM signal (Crank Angle Pulse).
7Throttle Position Sensor signal.
8Intake Air Temperature Sensor signal.
9Vehicle Speed Sensor signal.
10Starter signal.
11Switch signal.
11ECU/ECM.
12Knock Control Sensor signal.
12RPM signal.
13Knock Control CPU (ECM).
13RPM signal.
14Turbocharger Pressure.
14Ignition signal.
21Oxygen Sensor.
22Engine Coolant Temperature Sensor signal.
23Intake Air Temperature Sensor signal.
24Intake Air Temperature Sensor signal.
25Air-Fuel Ratio Lean.
26Air-Fuel Ratio Rich.
27Sub Oxygen Sensor signal.
28No. 2 Oxygen Sensor signal.
31Air Flow Meter signal (Vacuum Sensor signal).
32Air Flow Meter signal.
34Turbocharger Pressure signal.
35Turbocharger Pressure Sensor signal.
35HAC Sensor signal.
41Throttle Position Sensor signal.
42Vehicle Speed Sensor signal.
43Starter signal.
51Switch signal.
52Knock Sensor signal.
53Knock Sensor signal.
54Inter-cooler ECM signal.
71EGR System.
72Fuel Cut Solenoid signal.
78Fuel Pump Control signal.
81TCM Communication.
83
TCM Communication.
84TCM Communication.
85TCM Communication.
