msd with static timing? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2005, 10:13 AM   #1 (permalink)
View s3v3rth3stars's Photo Gallery
i am trying to run dual mikunis on a 4age. im having a hard time setting up the ignition but i think i finally have it. if i am running static timing will i be able to advance it when i get msd?
05 super white tacoma 2wd 4 cyl 5spd. single cab.
s3v3rth3stars is offline   Reply With Quote
Old 01-26-2005, 11:23 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You sure your timing is static? Because atleast on a 4A-F theres rpm advance done with weights, I'd imagine the same system is in the 4a-ge. However you'd need to mod the distributor to have LESS overall advance so that you can se the base level higher. If you set it as is, it would ping because you'd have way too much timing.
MSD wont bring any advantage over this setup.... if you want something better, get a TPS sensor put to the throttle shaft and get a SMT6 ignition controller and make a 3D map with the TPS signal and the rpm advance.
