so im new to the toyata world, more of a vw guy....anyways i got a 91 corolla (first ever) 4dr with a twin cam engine. the engine is from either a corolla gts or a celica but a cant find info as to the engine code location on the block. i looked around and found nothing but oilly grime. what i need to is order some parts to repair a dead headgasket. id also like to know some basic specs for a comp test. maybe horse power ratings ect but i can look that up after i know what engine ive got.
Well, usually you can tell what engine by the trim. What trim do you have?
I might be mistaken, but I think the code is supposed to be on the left side near the bottom of the block. Not sure on that though. And also I think it's written on one of those stickers in the driver's doorjamb.
i need to find the stamp on the block. the engine has been changed from stock...anyone? <- right of the engine block, near the distributor, facing the radiator.
cool.....okay it says 4a fe. what about timing marks? i see on the cam gear a dot and a line. where should they line up?i figuew on top of the valve cover to gasket surface on the front of the engine. also, what the rotor postion for #one cylinder.
omg, whats with this forum. i was asking about the cam timing not the crank timing.this is most likly my problem but i dont know if im out one tooth or like 30 deg.
and also, doesnt anyone know what the firing order is? 1,3,4,2?
