Thanks, and cruise control
Thank you guys for your quick response!
I have another question: the car has a cruise control but it does not work. I almost sure it was a after market one installed by previous owner. on the driver's sider firewall under the hood, there is a valve or motor (I do not know the exact name), which must be a Cruise control parts, because there is a cable connected to the throttle, it has a vaccume tube connected to it, and it also has some electric wires connected, but there is a two pin connector which does not connected to nothing, is it a spped signal connector? if it is, where is the speed signal come from?
It is strange that there is a wire jumped from fuse box (inside the car, on the left side of steering whee) to some where, I think it must related to the after market Cruise control instalation, Toyota should not have jumped wires from fuse box!
OK, the brake light works fine.
any clues are preciated, if you need, I can post some pics.
Thanks
