using oil quickly, no leaks.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2005, 07:32 PM   #1 (permalink)
View BlueRolla2002's Photo Gallery
I have a 2002 Corolla S, 5-speed. I seem to be burning up oil like crazy. I've checked everywhere and I don't seem to have any leaks. What could be the problem? This has never happened before, just started happening a few months ago.
BlueRolla2002 is offline   Reply With Quote
Old 02-05-2005, 08:01 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
What rate is like crazy?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-05-2005, 08:45 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251121
View REN69's Photo Gallery
Is it still under warranty?? I would take it to the dealer if I was you, and get it checked out.
Old 02-05-2005, 09:12 PM   #4 (permalink)
My oil light comes on about once every 5 weeks after refilling. I check the oil and it's very low. One time I checked it, it was dry as a bone!!!
Unfortunately it's not under warranty anymore. Figures after the 3 years is up things start to go wrong with it.
Old 02-05-2005, 11:41 PM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
How's the car run? if you would be burning that much oil you would see it in the exhaust for sure, have you ever pulled any plugs to look at them?..It might be a driving leak when the oil is moving around, check all around your engine(valve cover etc.) for oil..your car is fairly new so the engine should be clean and hopefully you can spot the problem area...good luck...Radd Guy
__________________________________________________ ______________________
"HONK IF ANY PARTS FALL OFF"
Raddman is offline   Reply With Quote
Old 02-08-2005, 02:18 AM   #6 (permalink)
View ratboycom's Photo Gallery
do you let your car warm up (or did you when you got the car new, if you got it new that is) or do you start it up and then red line the piss out of it?
ratboycom is offline   Reply With Quote
