There isn't a kit. Advantages? I don't know... attracts more chicks?
Anyways, you can either just have your stock hubs redrilled with a 5-lug pattern and put in new lug studs, or swap the hub itself with a 5-lug unit. I personally used the 5-lug hub from an '03 Matrix, along with the bigger brakes and rotor, but that's just because I had one available to me and I wanted to use the stronger Matrix outer CV joint. I had to machine the hub diameter (where it goes into the bearing) down about 2 mm, and make a little spacer so it looked just like the stock unit.
Now that's the front, for the back, I'm still working on that, along with the rear disk conversion.
