4a-gze tuning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2005, 05:30 PM   #1 (permalink)
View bmw5002's Photo Gallery
4a-gze tuning
What methods can be used to further tune a 4a-gze motor to get like 180+ hp? Custom ECU? Is there a way of increasing the boost level of the supercharger a bit more?
bmw5002 is offline   Reply With Quote
Old 02-07-2005, 05:40 PM   #2 (permalink)
View RakeRon's Photo Gallery
Most common things I've seen done to the 4AGZ are a new crank pully, a new supercharger pully, 272 duriation cams, aluminum flywheel, highflow exaust, and a new intercooler. From what I under stand that brings it up to 200hp (I believe this only goes for the 2nd gen 4AGZ found in the AE101s wich has 20 more hp than the first gen). I believe further tuning is very possilbe by installing a new stand alone ECU like the PowerFC or one of the current gernation piggybacks combined with some headwork, cam adjustments, and maybe even water injection or ITBs.
RakeRon is offline   Reply With Quote
Old 02-07-2005, 07:00 PM   #3 (permalink)
Gameroom cash: $134355
^^^^ you're quite off there....
the 2nd gen 4agze was in the ae92.... had the larger stock (10psi) pulley setup and 8.9:1 pistons, but was a bigport block and head..... it's rated around 165hp.... (US model is 145)..... the ae101 uses a smallport block/head and has a map system (all bigport 4agze's were afm)
you CAN NOT put itb's on a 4agze..... it's literally not possibl.... at least with the stock sc12.....
getting 200hp is tougher than you'd expect.... the sc12 is still pretty limited up top.... putting a lightened flywheel does NOT increase hp...... besides, a stock e51 flywheel is still lighter than any of the n/a C series flywheels (even though it's much larger). If you were to put some 272's into a 4agze, you'd lose some breathing down low and lose torque..... which is what is so great about the 4agze..... to be quite honest, up top hp in the 4agze just isn't fun and i find myself shifting early....
if you wanted to modify the setup.... .you can go with many different aftermarket setups... i'm currently using a (non tuned yet) megasquirt & edis4 to control mine.... i would suggest a set of mild cams, if you find a smallport 4agze then go with some n/a bigport cams..... change the i/c for a WAIC... that's much more efficient....
Old 02-07-2005, 07:30 PM   #4 (permalink)
Whats the difference with the smallport and bigport? I wasnt aware of this before. Which produces more power? So I'm looking for a JDM 2nd gen gze from an ae92 for 160 hp stock right?
Old 02-07-2005, 08:51 PM   #5 (permalink)
nice guy
View Foolish86's Photo Gallery
no one jump on my case...but i have heard some of the mr2 guys saying you could get 14 psi out of the sc12...new pullies and surge valve should do it
-"The Drift King wouldn't lie right? Better take the next hair pin at 90mph"
-"Soap don't take off the ugly...that takes sandpaper."
-"A poached egg isn't a poached egg at all unless it has been stolen from the woods in the dead of night."
Foolish86 is offline   Reply With Quote
Old 02-07-2005, 09:04 PM   #6 (permalink)
View hachi_slow's Photo Gallery
You could use an oversized crank pulley, fmic, stand alone ecu, the list goes on. If you talk to a lot of mr2 owners, they'll know.
I myself have the usdm gze engine with the accessories I mentioned and I'm putting down 180 whp.
hachi_slow is offline   Reply With Quote
Old 02-07-2005, 10:22 PM   #7 (permalink)
um, i am an mr2 guy
the nevo pulley gets you close.... to like 12-13 psi.... and so does the HKS pullley..... however, if you start getting that high then you need to block off your ABV (which also is a common mod) and disconnect the vsv that helps the s/c oil....
smallport has slightly milder cams, smaller intake ports (better flowing.... well, there are big debates about this), and an oil drainback on the back of the head to the oil pan....
ae101 4agze running on Megasquirt & edis4.... yes, that's my mr2
Old 02-08-2005, 12:24 AM   #8 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
just to clarify,
1st gen 4AGZE: AW11, AFM, Dizzy, Big port
2nd gen 4AGZE: AE92 Levin GT-Z (early model), AFM, DLI
3rd gen 4AGZE: AE92 Levin GT-Z (late model), MAP, DLI
4th gen 4AGZE: AE101 Levin GT-Z, MAP, DLI
hope this helps.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 02-08-2005, 02:42 AM   #9 (permalink)
your "3rd" and "4th" gens are the same.... they have the same head/block combinations, same intercoolers, same pistons, same pulley setup etc.... only visible difference is the ae92 oil dipstick is yellow and the ae101 is grey.... literally, that's it
some ae92's even came with lsd e58's
Old 02-08-2005, 03:11 AM   #10 (permalink)
VooDoo's Avatar
yup, mechanically they're the same. but there are other external features that differentiate the 3rd and 4th gen.
Grupo Toyota
Old 02-08-2005, 11:34 PM   #11 (permalink)
Um, so what are the stock hp/torque ratings of each generation?
Old 02-08-2005, 11:43 PM   #12 (permalink)
Voodoo whered u get the hood with the scoop on ur ride? Is that off the levin? And what the deal with the exhaust for the swap? Do i need custom manifolds and stuff or what?
Old 02-09-2005, 12:08 AM   #13 (permalink)
View Red_85_AE86's Photo Gallery
Originally Posted by VooDoo
just to clarify,
hope this helps.
AE111 ?
Red_85_AE86 is offline   Reply With Quote
Old 02-09-2005, 12:19 AM   #14 (permalink)
ae111 didn't have a gtz trim... it ended in ae101...... the ae111 upper models had the blacktop 20V
Old 02-09-2005, 12:24 AM   #15 (permalink)
The black top had different ITBs, cams, pistons, ecu .... what else ?
Was the MAP system the same ?
