Starting Problems 98 corrolla
I am having trouble starting my car, It takesme about 1-2 minutes and trying to start it up.The key turns all the way, and it makes a noise like its trying to start but nothing happens, and then i will turn the ignition and then car starts. Somtimes it will try to come on but doesn't, it will just die. All my lights work and my stereo comes on.Once started if i turn it off and start back up it works fine, but if it sits for a while more than 1 hour, I havehard time starting my car. its about 40 degrees at night and about 60's during the day. I don't know if its a battery issue or a starter issue, I had some Corrosion on the battery terminals but i cleaned that off, and it worked fine for a while but my problem came back. Any suggestion, tips in helping me solve my issue, could it be the battery or starter? Thanks for the feedback. coud it be my spark plugs? don't know when the last time i changed it, its probably been over 2 years
