AE86 ( Dropping the engine cradle 1" ) ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2005, 07:04 PM   #1 (permalink)
View Red_85_AE86's Photo Gallery
I would like to make a 1" spacer for the cradle and drop the engine a bit ... what precautions should i take ?
Will the drive-shaft and steering-shaft be ok ?
Red_85_AE86 is offline   Reply With Quote
Old 02-08-2005, 07:24 PM   #2 (permalink)
View Rust_bucket's Photo Gallery
dont do it! You will get some serious vibrations from the rear end due to the fact that you just changed the whole geometry of the drivetrain...
Proving people wrong 10psi at a time... t'ill the motor blows then I have no more to prove really...
Rust_bucket is offline   Reply With Quote
Old 02-08-2005, 07:30 PM   #3 (permalink)
the stock drive shaft is 2-piece .... so should it not be able to bend a bit ?
so how about when the rear suspention travels up and down when you go over bumps ... it changes angle than ... no ?
Old 02-09-2005, 07:12 AM   #4 (permalink)
whats the reasoning behing lowering the motor though?
Old 02-09-2005, 08:00 AM   #5 (permalink)
- the HKS Turbo Kit
- ITB/MAP setup
- lower center of gravity
- Mr. RE-Amemyadoes that to his cars ( drops them down and pushes them back )
i have seen the insert plates on a Japanese company's page .... lost / forgot the link, but all it was is:
- 2 plates for the cradle
- 2 or 4 round washers for the trany
Old 02-09-2005, 10:40 AM   #6 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
It makes sense weight-distribution wise. They do that with open class rally cars.
Wether or not the drivetrain will be OK I have no idea.
Chris Corolla S is offline   Reply With Quote
Old 02-09-2005, 02:53 PM   #7 (permalink)
Check out this motor ( nice-n-low ) )
Old 02-09-2005, 04:59 PM   #8 (permalink)
yo soy "EL CUCUY"
CUCUY's Avatar
View CUCUY's Photo Gallery
if you do it...make sure you do it right and everything is secure and no slop. how ever much you drop the motor, you should drop the tranny the same. and yes, the drive shaft is 2-piece, but i don't know if it'll stand that much of angle. you might have to buy a kit and "re-level" your whole rear end.
CUCUY is offline   Reply With Quote
Old 02-09-2005, 05:55 PM   #9 (permalink)
My plan is to get a custom aluminum one-piece shaft once the motor/trany is lowered
Old 02-09-2005, 06:57 PM   #10 (permalink)
yo soy "EL CUCUY"
CUCUY's Avatar
i dunno about a 1-piece...geometry offset might be too much
Old 02-09-2005, 09:54 PM   #11 (permalink)
nice guy
View Foolish86's Photo Gallery
i would stick with the two piece...i mean...the second piece would be level with the rear end
-"The Drift King wouldn't lie right? Better take the next hair pin at 90mph"
-"Soap don't take off the ugly...that takes sandpaper."
-"A poached egg isn't a poached egg at all unless it has been stolen from the woods in the dead of night."
Foolish86 is offline   Reply With Quote
Old 02-09-2005, 10:06 PM   #12 (permalink)
Muscle car guys get one-pice aluminum shafts for their cars, because you lose power with a 2-piece and a lighter rotating mass will send more power to the wheels .... there is a guy here that already has one in his corolla .... i want to hear what he has to say / add about his experience with it.
Old 02-09-2005, 10:14 PM   #13 (permalink)
nice guy
i know i bunch of older mucsle car guys and most of them have two piece alluminum...why would the second piece make it lose power if it was allumimum aswell
Old 02-09-2005, 11:14 PM   #14 (permalink)
operation boro thunder
View project trueno's Photo Gallery
I would love to get some Cusco lowering mounts, lower engine=lower CG guys, think boxer engines.
1-piece driveshafts eliminate that rotational "lag" caused by the U-joint between the two half shafts. However I'm not sure if it will yield significant amount of power, but it'll do wonders for direct response and pick-up.
I personally would stick with a 2-piece driveshaft for its adaptibility to movement, its more forgiving when the drivetrain geometry is slightly out of shape. With a 1-piece, having setup the shaft to be in the same center axis as the transmission and diff. may cause problems if suddenly your car has to endure over pavement with uneven elevation. (For a strictly off-road race car this is not a problem.)
Whatever your decision may be, adjust the mounts until you have the transmission center axis parallel to the diff. center axis, even if they are not on the same plane.
project trueno is offline   Reply With Quote
Old 02-10-2005, 07:30 PM   #15 (permalink)
nice guy
you guys are cool....
when i get my new engine, i am going to drop mine about an inch.
