AE6 ( LSD independant rear-end from Supra / Celica ) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2005, 10:09 PM   #1 (permalink)
View Red_85_AE86's Photo Gallery
I remember people mentioning this before, jst want to know if it is a relativly easy swap or not.
Links / pictures / contacts would help .... thanks
Red_85_AE86 is offline   Reply With Quote
Old 02-09-2005, 10:12 PM   #2 (permalink)
nice guy
View Foolish86's Photo Gallery
that would depend on what your definition of easy is....i haven't done it...but i want to do it...so find out for me to
-"The Drift King wouldn't lie right? Better take the next hair pin at 90mph"
-"Soap don't take off the ugly...that takes sandpaper."
-"A poached egg isn't a poached egg at all unless it has been stolen from the woods in the dead of night."
Foolish86 is offline   Reply With Quote
Old 02-10-2005, 06:57 AM   #3 (permalink)
Looks like i found a contact
http://www.sdsefi.com/features/aug03corolla.htm
Jamasco Auto Repair
5755 FUNSTON STREET HOLLYWOOD, FL 33023
954-985-9958 Contact:Jayson
Import specialist,custom fabrication.
4AGZE
- SDS EM-3 4F
- Steel head gasket (from 95 1.8L Corolla)
- 65mm Toyota throttle body
- T04E/T3 Hybrid Garrett Turbo / HKS turbo velocity stack
- MSD 756cc injectors
- Holley 255 LPH in tank fuel pump
- Isuzu FMIC
- HKS twin sequential blow off valves
315.1 hp and 273.4 ft/lb @ 24-25psi on 117 octane and 93 octane mixed fuel.
289.3 hp and 230.2 ft/lb @18psi on 93 octane fuel
- 89 non-turbo Supra transmission
- FWD flywheel from 88 Corolla GTS
- ACT Xtreme pressure plate
- Custom 4 pad ceramic clutch with Supra center spline,
- 86 SR5 automatic drive shaft
- The rear end setup is from a 79 Celica/Supra
Old 02-10-2005, 07:15 AM   #4 (permalink)
View Rust_bucket's Photo Gallery
something is wrong with those hp numbers...
Proving people wrong 10psi at a time... t'ill the motor blows then I have no more to prove really...
Rust_bucket is offline   Reply With Quote
Old 02-10-2005, 06:39 PM   #5 (permalink)
View ii ndica ii's Photo Gallery
i too would like to do this swap, gts are good as dead around here, cant find one at all.
there are 3 of us now, if anyone has experience with this swap please help.
thanks.
ii ndica ii is offline   Reply With Quote
Old 02-10-2005, 07:00 PM   #6 (permalink)
nice guy
those hp numbers seem....way to high...
Old 02-10-2005, 07:08 PM   #7 (permalink)
Immortal
View Kwanza's Photo Gallery
79 Celica Supra rear-end is a solid axle. An IRS set-up from the more recent 7M Supra Celicas would be slightly more challenging...
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 02-10-2005, 07:13 PM   #8 (permalink)
Would the solid ends from the Supra / Celicas from those years have factory LSD ?
Old 02-10-2005, 07:21 PM   #9 (permalink)
Those numbers are too low..
Old 02-10-2005, 07:40 PM   #10 (permalink)
Immortal
I can't say regarding a stock LSD... but those 7.5 inch Diffs are the same as the ones in the trucks... so you have a wide range of choices as far as LSDs, gear sets, lockers and things go... ;]
Old 02-10-2005, 07:45 PM   #11 (permalink)
View boi_si's Photo Gallery
seen one before.. looks like 240sx rear end.. not sure though.
-03 Matrix XR
-90 Celica turbo Alltrac
boi_si is offline   Reply With Quote
Old 02-10-2005, 10:14 PM   #12 (permalink)
i tought 240s had intependant suspention
Old 02-11-2005, 11:40 PM   #13 (permalink)
yes its independent.. not sure if its 240sx but im thinking it is... due to the 4x114 pattern. i remember the pic in drifting.com...
-03 Matrix XR
Old 02-12-2005, 02:14 AM   #14 (permalink)
Immortal
I can name quite a few IRS setups that are 4x114.3 that aren't 240's... ;]
Old 02-13-2005, 11:55 PM   #15 (permalink)
name IRS with 4x114 bolts...
-03 Matrix XR
