motor question? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2005, 11:15 AM   #1 (permalink)
Loud Street Machine!
View 89rolla's Photo Gallery
motor question?
Is there a way that i can make my 4a-f carbed, into a fuel injected, there is the 4A-fe which is fuel injected and isnt it the same motor except for that difference??
i just want to have a fuel injected motor (cheaply) and if that is any cheaper than buying a whole new motor and dropping that in, than i will do that!
AE92=
89rolla is offline   Reply With Quote
Old 02-14-2005, 11:44 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
4A-FE has a different head, the head has injector holes machined into it... but you can make a stand alone EFi system into the 4A-F.
Old 02-14-2005, 11:45 AM   #3 (permalink)
Gameroom cash: $147537
Probably not. Think about MAP sensoer, cold injector, ECU and wiring harness. Easier to get everything and drop it in. Then why not go for 7A-FE or even 4A-GE since you have to went through all those trouble.
Old 02-14-2005, 12:33 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Its not really that hard to rig up a EFi setup.
Old 02-14-2005, 01:38 PM   #5 (permalink)
so whats the best thing to do then, hook up an efi system, or drop a new motor??
or should i say what is cheaper?
AE92=
Old 02-14-2005, 02:00 PM   #6 (permalink)
Not hard as long as one know what to do. A swap maybe less headache.
Old 02-14-2005, 04:43 PM   #7 (permalink)
so if i went to the local junkyard here and found a corolla sr-5 or gts, i could use the motor and ECU from that, and drop it in mine?? are the motor mounts the same, cause thats my biggest worry, i dont want to have to change those!!
AE92=
Old 02-14-2005, 05:09 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
definately less of a headache to swap in a new one. But I'm always the one that takes the harder route... so I guess I'd be the one making a manifold for an crazy EFI setup
