No brakes!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2005, 01:13 PM   #1 (permalink)
since 1996
Voodoo.Priest's Avatar
View Voodoo.Priest's Photo Gallery
Unhappy No brakes!?!
What I had suspected with my brakes ended up being true and a little worse then I thought. My whole braking system died all at once. All my calipers are siezed, rear pads are done, 3 rotors are worn out and one of my calipers had a leak. I'm not shocked or surprised at this at all because I knew it was comming soon but I was hoping not until the spring.
Since I'm looking at basicaly $900 worth of parts to replace does any body know of any decent brake kits for $1,000 or under? I'm just thinking I may as well get a kit and through in the brake lines as that is the only thing that is basically not going to be replaced. If not a kit then at least just chaeper parts.
Also reading stuff from a search I did on DoriKaze, OEM pads are $50? If so I'm gonna check OEM prices as well.
Here is what I'm looking at as far as parts right now on my quote:
Brake pads front: $93.80 ea
Brake rotor front: $28.62 ea
Brake caliper front: $99.73 ea
Brake pads rear: $81.45 ea
Brake rotors rear: $28.36 ea
Brake caliper rear: $148.42 ea
Just got some prices from Toyota:
Front pads: $58.63 ea
Front calipers: $653.08 ea
Front rotor: $105.90
Rear pads: $58.63 ea
Rear calipers: $571.97
Rear rotor: $95.00 ea
1997 Corolla SD sold __________________ 1986 Corolla GT-S liftback *Christine* R.I.P.
1986 Corolla GT-S liftback *Ashley*_____ 1986 Corolla GT-S coupe *Martha* R.I.P
2005 Impreza RS 2.5
Voodoo.Priest is offline   Reply With Quote
Old 02-15-2005, 12:34 AM   #2 (permalink)
View ratboycom's Photo Gallery
get some hawk or axis pads they are cheaper and better than stock, and call junk yards about calipers they should be a lot cheaper for a rebuilt one, check nopi they stock a fair amount of stuff allong those lines
ratboycom is offline   Reply With Quote
Old 02-15-2005, 06:44 AM   #3 (permalink)
View MississaugaGTS's Photo Gallery
Pull your calipers apart and try to compress the piston. If it moves, then the sliders are probably siezed not the caliper itself. The last person to own my car didn't use high temp grease on the sliders which caused the sliders to become badly pitted and they siezed!
There's a shop in Mississauga at Tomken and Bloor called Applewood Service Centre. It's just an every day garage but the guys who own it/work there have a couple of AE86 rally cars. They also do engine swaps. They seem to be pretty knowledgeable and pricing is usually not too bad. I'd try calling them.
MississaugaGTS
MississaugaGTS is offline   Reply With Quote
Old 02-15-2005, 08:38 AM   #4 (permalink)
View 89TCGTS's Photo Gallery
one suggestion.....you might try a junkyard.....i had to get a whole new rearend for my 89 gts, because i hit a curb, and the whole thing cost me $75. It came with everything, all braking parts, shocks, springs, and sway bars. It takes some work finding one to get parts off of, but there are other cars that have the same parts.
89TCGTS is offline   Reply With Quote
Old 02-15-2005, 11:47 AM   #5 (permalink)
since 1996
The caliper pistons are all gone, so sadly I do need new/reconditioned ones.
2005 Impreza RS 2.5
Old 02-15-2005, 12:50 PM   #6 (permalink)
Gameroom cash: $134355
don't go through toyota..... they just have remanufactured parts like all parts stores... only difference is theirs say toyota on them....
actually, many parts stores have good warranties on their parts..... i'm also looking to do brakes on my mr2 (aw11)..... for some vented rotors i'm looking at about $50 for the pair and i found some carbon metallic pads for ~$35.... i can't see the price on an ae92 being much more
as for the calipers... you can actually get new pistons and a rebuild kit if you wish.... on my old aw11 i had 2 seized rear calipers, and all we did was pull them off, pull the caliper apart and clean it all up/regrease it and it worked great afterwards....
Old 02-15-2005, 02:14 PM   #7 (permalink)
Dis reg!
AEugene86's Avatar
View AEugene86's Photo Gallery
I went to Partsource for my rebuild calipers, you can trade in your old ones. It was about $350 core (after trade in) for all 4 calipers. for rotors and pads. go to pdm-racing.com check out their "toyota corner", well priced cross drilled rotors and kevlar pads, and they have stainless steel brakelines too. highly recommended. thats what I did.
'87 Corolla GT-S HB
AEugene86 is offline   Reply With Quote
Old 02-16-2005, 12:37 AM   #8 (permalink)
if you want steel braided lines i have a hook up for $40 a side for the fronts
Old 02-16-2005, 03:51 PM   #9 (permalink)
View martiniracing's Photo Gallery
gord, how soon do you need all the brakes done? i'm planning to go with bigger brakes all around, i have 3 month old:
- brembo front discs (solid blanks)
- magnum rear discs (solid blanks)
- complete rebuilt and gold painted front and rear calipers
- pbr metallic pads
all of them 3 months old
lemmie know if you're interested, shoot me an offer
sell your car free!
www.projectsource.ca
martiniracing is offline   Reply With Quote
Old 02-17-2005, 12:17 AM   #10 (permalink)
since 1996
I'm currently out of work so I need my car to get to interviews. So I have already odered all the parts. Unfortunatly I found out my brake master cylinder ain't working no more ether. So now I need one of those as well.
One thing that pisses me off though is I ordered all the parts and specifically told them GT-S parts and nothing else and they gave me the entirely wrong set up for the front and wrong pads for the back...
2005 Impreza RS 2.5
Old 02-19-2005, 09:58 AM   #11 (permalink)
View oreo's Photo Gallery
I've lost count on how many times i've ordered parts for my 86 and got the wrong parts...
if u'r calipers are off the car i know a place u can get them rebuilt for 'bout 300 or less for all four.
oreo is offline   Reply With Quote
Old 02-19-2005, 10:19 AM   #12 (permalink)
N/A bites
Tercel GTS's Avatar
http://partsamerica.com
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
