92 Ee-90 Starter/fuse Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2005, 10:55 AM   #1 (permalink)
kjt
View kjt's Photo Gallery
I have a -92 corolla (1.3 EE-90). Now the main fuse (40A green by the battery) has blown three times in 6 days. It blows when I turn the key. When it blows the starter and instruments gets no power. I can start by pushing the car, but no instruments, radio or blinker will work. I assume there is a shortcut somewhere. Anyone that know about this?
Regards
Karl
kjt is offline   Reply With Quote
Old 02-15-2005, 08:02 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
start by checking the grounds and battery connections
Old 02-16-2005, 02:29 AM   #3 (permalink)
kjt
Tried that, but no change...
Old 02-16-2005, 10:37 AM   #4 (permalink)
View 89TCGTS's Photo Gallery
find your alternator......check and make sure the power wire is connected. If it is the trace it back to the battery.....look at the wire to see if there is any burn marks on it because it could be hitting your manifold, or some other part of the motor, and burnt through the plastic. if that isn't the problem then look at all wires running from the battery to you fuse box and etc. there has to be a short somewhere along the line.....thats the only reason for that to happen
89TCGTS is offline   Reply With Quote
