The higher of the two is fill plug (For clarity you may already know some of the following too.)
get some 3/8 tubing (I use clear tube) about 3 feet and to reach the fill plug from engine comaprtment, and a funnel.
Make sure that you can open that Fill plug first! you cannot drive with it emptied of oil
then loosen lower 10mm plug, put drain pan under,
open and take out plug and let it drain.
replace drain plug. leave pan in place.
open fill plug
Pass tube from above and then jam it into fill hole.
on top, jam in funnel, and poir new fluid till it runs out of the hole (thats why the drain pan is left there) when fluid runs out it is at proper level.
remove fill tubing, and put in the fill hole plug.
I like coating the threads with some pipe dope (teflon paste) to make sure it seals well, and doesn't corrode.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
