Electrical problem in 91 Corolla
Hey, anybody ever had an electrical problem where the windshield wipers come on when you disconnect the negative battery cable while the engine is running?? I figured that there is a short someplace. I pulled the wiring harness from the alternator and pulled the negative clamp from the battery and connected a test lamp on the negative clamp and the negative battery pole and the light comes on. I pulled each fuse and none made the light go off. Except for the dome light fuse, when i pulled that fuse, the test light dimmed but didn't go off. I'm stuck now. Any suggestions or has this happened to anyone before??
