Timing problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2005, 02:35 PM   #1 (permalink)
View MN-Corolla's Photo Gallery
Timing problem
Hi all,
I'am new to Corollas and Toyotas in general. I have a 1994 Corolla 1.8L DOHC 5 spd. We got it for $250. Here is the problem. The head gasket was blown and we received the car with the head and cams removed. I'am pretty mechanically inclined. I do performance work to Jeep I-6 4.0's all the time. But toyotas are new to me.
I have the new gaskets kit and I'am ready to reassmeble the engine. What is the best way to put this back together to get the timing right??
Any help would be greatly appreciated.
Brian
MN-Corolla is offline   Reply With Quote
Old 02-22-2005, 02:53 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Set the engine to TDC and then start from there. then get a timing light and set the timing advance.
Old 02-22-2005, 03:03 PM   #3 (permalink)
I hear you on TDC. But what about the cams. I dont see any marks to know what is correct way to install them.
Is there a certain way the cams must go in? I see a diagram in the Chiltons manual, but I'am not sure if it is for my engine.
Mine is the FI 1.8l DOHC.
Does it require a timing light? I'am guessing the advance must be on the Distributor?
Thanks again
Brian
Old 02-22-2005, 03:45 PM   #4 (permalink)
Gameroom cash: $147537
First you need to match the cam gear. Follow the manual on matching the marks on the gear. After that, put cam pulley back on. There is a small hole on the pulley and it should be at top when engine is at TDC.
Old 02-22-2005, 10:19 PM   #5 (permalink)
Ok, I talked to my buddy tonight. It turns out it is a 1.6l DOHC. I misheard him on the phone. Does this make any difference?
Brian
Old 02-22-2005, 11:34 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
no
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 02-23-2005, 06:59 PM   #7 (permalink)
View TekPhobia's Photo Gallery
I only hope there's a M8x1.25 bolt in the intake cam gear. The DOHC setup is achieved using a slave cam setup. You've got the main gear, on the intake cam, and a sub-gear to reduce backlash. If there isn't a bolt holding them together when you remove the cams, the dimples will be off when you re-assemble the motor. Don't worry, the motor is non-interference.
I'd recommend getting a Haynes/Chilton for re-assembly.
-Tim
TekPhobia is offline   Reply With Quote
Old 02-24-2005, 12:06 AM   #8 (permalink)
I did not see any bolt. How do I go about fixing this problem?
I have a chiltons book. But I was looking for a little extra insight.
Brian
Old 02-24-2005, 12:27 AM   #9 (permalink)
It's a PITA, but you're gonna have to hold the main gear steady and rotate the sub-gear and you'll see the threaded holes line up. Then, just thread in a bolt and voila.
-Tim
Old 02-26-2005, 06:49 AM   #10 (permalink)
Well, we got it started. Not nearly as hard as I thought. Started her up and tuned the timing a bit and it runs like a charm. Problem is it was missing the bolts holding some of the cooling lines on. Currently it does not have coolent so I cant run it for more than a few minutes at a time. I will be making a run to the U-Pull today to see if I can find them.
Is there anything I should be on the look for? I'am watching for leaks, and I noticed the stock exhaust manifold has a huge crack in it. Any good places to get a new one.
Anyways, thanks for the help.
Brian
Old 02-26-2005, 09:20 PM   #11 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
get a manifold and the head studs too
