Cody,
Definitely CV joints with the clicking sound. You're probably lookin' at around $400 from a fair shop to have both axles replaced......(you always do them both at the same time). Once you have them replaced you're good for at least another 100,000 miles.
Wheel balancing could be part of the problem, but as soon as you said, "clicking", that's about a 99.9% sure sign of CV joint probs.
On the bright side, you don't need to run out tomorrow & get it done. Do some homework. Call local shops........check your pennysaver.......also call AutoZone & the like to see what they want per axle. (They'll call them "stub" axles meaning an axle with the CV joints already on each end and ready to bolt up).
It's not necessarily a job you want to do yourself.
The axles should run between $50 for cheapies to $100+ for good ones or OEM. Being that you're gonna spend a couple hundred in labor, I'd go for some good ones. Spend something closer to $100 each and find out what kind of warranty they come with.
If you have a Pep Boys around you, you can shop the price on the axles alone & then ask them what they want to install them. You could also just have the particular CV joint replaced, but if it's an older car, might as well do both axles right now. You'll feel a lot better about your car when they're done.
