7afe and 4afe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2005, 10:06 PM   #1 (permalink)
View lifeisviewtiful's Photo Gallery
7afe and 4afe
maybe this is a repost but i wasn't very specific before. how can i tell by inspection, the difference between these 2 engines? i already know one is 1.6 and the other is 1.8. i want to know how can a person be able to tell the difference upon close inspection of the engine itself.
lifeisviewtiful is offline   Reply With Quote
Old 02-25-2005, 11:59 PM   #2 (permalink)
please help
Old 02-26-2005, 12:04 AM   #3 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Normally there's a tag that says what it is under the hood, but I can't think right now of the external differences between the two engines...
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 02-26-2005, 03:11 AM   #4 (permalink)
Gameroom cash: $134355
oil pans are different... 7a blocks are taller.... the stamping on the block says "7a" on it... to name a few
Old 02-26-2005, 04:08 AM   #5 (permalink)
The Mad Scientist
Do you know what the different external heights are? Could you take a tape measure and figure it out that way?
Old 02-26-2005, 09:29 AM   #6 (permalink)
where on the block do i look for the stamp to tell where it says 7a
Old 02-26-2005, 11:24 AM   #7 (permalink)
ems
View ems's Photo Gallery
They also have different valve covers. If you show us a picture we should be able to tell you which is which.
ems is offline   Reply With Quote
Old 02-26-2005, 02:15 PM   #8 (permalink)
ok will do
Old 02-27-2005, 02:20 PM   #9 (permalink)
only between an early 4afe and late 7afe.... if you were to look at a 95 4afe and 95 7afe the valve covers should be the same -- the heads are the same... earlier 4afe's used 3 bolts to hold the valve cover down, later i believe they switched to 4
Old 02-27-2005, 02:21 PM   #10 (permalink)
you probably could.... but I personally don't know....if the oil pan was off you should be able to figure out by the crank as well, as it will have a longer stroke than a 4a block
