15" Tire sizes for AE92 Corolla sedan?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2005, 07:34 AM   #1 (permalink)
Loud Street Machine!
View 89rolla's Photo Gallery
what is the widest possable 15" tire that i can get for my AE92 with just stock suspension..and the rims are off a Mazda MX-3 Precidia..could i fit a 215/50??
AE92=
89rolla is offline   Reply With Quote
Old 02-28-2005, 07:38 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I cant say without knowing what the rim specs are. I have 195/55R15 on my car for summer.. its wide enough for a light car like that plus there isnt much space to go bigger really.
Old 02-28-2005, 01:20 PM   #3 (permalink)
oh..cause i was told that i could do 205/50R/15 on my car and it would be fine..i just wanted to know how wide you could go...thanks
AE92=
Old 02-28-2005, 01:45 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
I suppose you could put 205's on, but I dont know how the clearance would be.
Old 02-28-2005, 06:28 PM   #5 (permalink)
View ratboycom's Photo Gallery
ok you have the same rims as me so ill give you a straight answer,
205s will fit but you need to add a small (cant remember how small but like 1/4 - 3/8 inch) spacer in the rear otherwise the tires will be stuck on the strut housing, with the spacer the tires will rub for a little while but that was just from the letters on my tires, if you want i can get the spacers for about $8 each i could get some and send them to you
ratboycom is offline   Reply With Quote
Old 02-28-2005, 06:38 PM   #6 (permalink)
these ones were on ebay, they should do the trick
Old 04-05-2005, 06:31 AM   #7 (permalink)
View darien's Photo Gallery
sir it will depend mostly on two factors. first is the size/height of the sidewall and 2nd, the offset of your rims. 205s i think are the fattest tires you can comfortably fit in your ae92. i used to have 205/45/16s in my ae92. but i have to put 1/4 inch spacers at the rear to keep the inner sides of the tires from rubbing against the suspension. i also replaced the rear bolts with longer ones to compensate for the installation of the spacers.
darien is offline   Reply With Quote
Old 04-05-2005, 02:24 PM   #8 (permalink)
View MississaugaGTS's Photo Gallery
I put 205/50R/15 on my AE92 GTS because someone told me they would fit! I returned them the next day because the sidewalls were getting torn to shreds!
195/50R/15 work quite well now!
MississaugaGTS
MississaugaGTS is offline   Reply With Quote
Old 04-05-2005, 04:41 PM   #9 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273721
View REN69's Photo Gallery
yeah... 195/50-15 are closest to stock... anything after that is too wide and too tall and your speedo will be off by a lot... and on top of that.. like mississaugaGTS stated above.. you'll ruin your tires.
