Stright exhaust route ( AE86 ) ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2005, 04:01 PM   #1 (permalink)
View Red_85_AE86's Photo Gallery
Couple of places i went to told me that they can't make my exhaust pipe stright .... and i need my exhaust redone because the car is lowered 2" and i have tha 4 links installed ... and they are hitting ....
So i am just wondering if anyone has a stright exhaust on the AE86 and how did they do it ?
Thanks
Red_85_AE86 is offline   Reply With Quote
Old 03-02-2005, 08:08 PM   #2 (permalink)
86 is one who drifts
View DRIFTASSAULT's Photo Gallery
I had the same problem as you a while ago. I had a jic catback and had to cut it in 2 places: at the muffler and where it just starts to bend up to go over the axel. All i simply did was find a peice of SS piping and weld it in place of the cut out portion. Also have a joint in the pipe just before it goes under the axel because if you ever jack the car up by the frame then the axel will lower and bend the pipe (depending on size and quality of the pipe).
Salt ruins cars
I'm a jitbag. Whats that?
DRIFTASSAULT is offline   Reply With Quote
Old 03-03-2005, 03:43 PM   #3 (permalink)
So you have it going over the rear diff ?
I am looking for someone who has it routed under the diff ....
ohhhh, update .... look what i found here
Old 03-03-2005, 04:01 PM   #4 (permalink)
View Fabius's Photo Gallery
what a waist it still has a cat
Fabius is offline   Reply With Quote
Old 03-03-2005, 05:54 PM   #5 (permalink)
Does it ?
I think that is removable section .... made to look like it has a catacitic converter .... but i don't think cops will fall for that ( if they are smart ... to know that it needs to be close to exhaust side to work )
Old 03-06-2005, 05:25 PM   #6 (permalink)
no under, sorry for the confusion
Salt ruins cars
Old 03-06-2005, 05:44 PM   #7 (permalink)
View Rust_bucket's Photo Gallery
You cant run the exhaust under the car... you'll destroy it...
Proving people wrong 10psi at a time... t'ill the motor blows then I have no more to prove really...
Rust_bucket is offline   Reply With Quote
Old 03-06-2005, 05:50 PM   #8 (permalink)
I've had mine for a year now and it fine
Salt ruins cars
Old 03-06-2005, 05:52 PM   #9 (permalink)
what is it 1 1/2"?
Old 03-06-2005, 06:36 PM   #10 (permalink)
View 1985rollasr5's Photo Gallery
yea i have the same issue, i had to cut it right after the cat, but the other day i hit a bump and it crushed the cat so i had to cut it off and well its way to loud now, so i had to take the stock pipe from my other ae86 and put it on, well when i got into the car to start it the rear end smashed the ehaust pipe. there is about 1 1/2 of room between the under body and the rear end, so this coming weekend im goin got hagve towork
kjbkj
1985rollasr5 is offline   Reply With Quote
Old 03-06-2005, 07:07 PM   #11 (permalink)
shooot ... so i guess i am gonna have to find a way to run it over the diff ...
Old 03-06-2005, 07:58 PM   #12 (permalink)
operation boro thunder
View project trueno's Photo Gallery
There are tons of aftermarket cat-backs for AE86, in the under diff configuration.
Yes when you jack the car the axle housing will come down, crushing the exhuast. You could compensate by using 2 jacks and keep the axle housing from touching the pipe. Or you could get short stroke dampers, the housing might clear the pipe depending on your settings.
project trueno is offline   Reply With Quote
Old 03-06-2005, 09:57 PM   #13 (permalink)
so must of the guys that lower there cars run it under the rear end???
kjbkj
Old 03-06-2005, 10:05 PM   #14 (permalink)
some people run it over diff, some under diff. Personal preference.
I personally will go with aftermarket overdiff
Old 03-06-2005, 10:19 PM   #15 (permalink)
see i put the stock exhaust on witch is only 1 5/8 and when i hit a bump it hits the pipe, and im going to put 2 1/2 here this week so i HAVE to go under i guess
kjbkj
