i hope. im not really even sure what the engine is. all i know is its a DOHC 1.6L I4.
like i said before.. im going to sound like an idiot until i know my way around a toyota.
__________________ been beaten down but the hate still breathes
You'll need the tranny, flywheel, clutch kit, clutch cylinder, slave cylinder, clutch lines, clutch pedal, shift linkages, shifter assembly, and some time...
Brake pedal, shifter cables. The slave cylinder and linkage should come with the tranny. Also, you need to make some wiring changes. And I don't think you need the flywheel but I could be wrong on that car.
The total cost is usually around $1000 including labor at my shop.
BTW you have either a 4AFE or a 7AFE, but most likely a 4AFE. Also, doing an auto/manual conversion and keeping the stock engine usually is a lot more work than it's worth since for the same price you can buy the car with it already done, however, if you're doing an engine swap anyway and the tranny with the engine is a 5-speed, it's a lot easier since you're already pulling everything out anyway. In that case, it's worth it.
Brake pedal, shifter cables. The slave cylinder and linkage should come with the tranny. Also, you need to make some wiring changes. And I don't think you need the flywheel but I could be wrong on that car. www.phoenixtuning.com
Hehe... the brake pedal should already be on the car... ;] You'll sure be needing that clutch pedal though... Also... you will need the flywheel for ANY auto to manual swap. Automatic trannies use flexplates, manuals use flywheels and clutches. When you buy a tranny, you'll be lucky if you get one with a slave attached, but for the most part, expect those parts to be on the list... ;] Wiring changes might be neccesary depending on which series ECU and what sorts of sensors are on the tranny. The car will still work, but with no signals from those sensors, the ecu will throw codes.
__________________ It's ok to be naked, girl... I'm an Artist!
Stop and think about this for a minute. Automatic... manual... automatic... manual... brake pedal... clutch pedal... brake pedal... hmm....
The clutch start switch will also need to be wired up, or the neutral start switch bypassed.
This topic has come up before, and has been the subject of hot debate. Do a search here (top of page), and you will find more info. Some here think that no matter what your skill level you should just go ahead and tear the car apart replacing the transmission. Others, like myself, contend that with the wide availability of the '88-'92 AE92 Corollas it is much more cost-effective to just find another vehicle. There are lots of these cars out there with manual transmissions, and if the autobox box bothers you that much you should just go find one. It really would be easier and cheaper. For the grand you will spend on parts you could find lots of Rollas with sticks. The auto trans is actually a plus if you were to trade the car in at a dealership, as automatics are easier for them to sell. Find a 5-speed you like on a lot, grease the lot owners palm with $200-$300 and your car, and drive off into the sunset rowing gears all the way! Regards, Aaron
