Internal mods on a 5A motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2005, 02:11 PM   #1 (permalink)
AE92-KrAyZiE!!!
PPW-546's Avatar
View PPW-546's Photo Gallery
Question Internal mods on a 5A motor
Peeps,
is it possible to put in high comp pistons for a 4AGE into the 5A motor? And what type of cams should I put in to add more ponies? Lift and Duration? Other ideas on how to increase HP on my 5A? I want to play with the engine first before i decide if I would replace it or not, depends if i get the desired performance I want.
Thanks!
________________________
http://www.cardomain.com/id/krayzie_ae92
PPW-546 is offline   Reply With Quote
Old 03-03-2005, 02:31 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Never heard of the 5A... what's the complete engine code??
We don't have a 5A powered AE92 in North America as far as I know...
A-series stuff is usually interchangeable though...
Chris Corolla S is offline   Reply With Quote
Old 03-03-2005, 03:32 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
5A is a 1.5liter if I remember correctly.
Old 03-03-2005, 09:32 PM   #4 (permalink)
mrboxman
View mrboxman's Photo Gallery
i have a 5A-fe same thing probably, i from Trinidad in d caribbean and alot of our cars are JDM because of the huge 'foreign used' market. But its pretty hard to get aftermarket parts for the 5a in my search locally most mods are for the 4a-ge
mrboxman is offline   Reply With Quote
Old 03-04-2005, 01:01 AM   #5 (permalink)
View Johan's Photo Gallery
Hi,
The 5a is nearly the same as the 4a. Smaller bore , pistons and minor differences on the head.
Do any of you guys have any documentation on the motor? I replaced my 4af with a 5a but i need some info on the carburator. We in South Africa Are only now getting Cars with cathylic converters on our vehicles. I need to bypass all the vacuum pipes on the carb. Any info will be a great help.
Johan is offline   Reply With Quote
Old 03-04-2005, 01:09 AM   #6 (permalink)
View automatic's Photo Gallery
Johan, the car may run too rich with all the vacume lines plugged, not good in an area that is high altitude to begin with.
You may need to re-jet the carb after plugging off the spare lines.
automatic is offline   Reply With Quote
Old 03-04-2005, 10:54 AM   #7 (permalink)
AE92-KrAyZiE!!!
PPW-546's Avatar
5A motor is the same as the 4A motor, but with lower displacement and carb-fed. If i bore the cylinders to say 1600cc, would the high-comp 4AGE pistons work? what would be the differences in the head of a 4A motor vs the 5A?
Johan,
I took a good look at my carb this morning and I only saw 3 vacuum lines. one going to the valve cover, one to the intake manifold and i cannot distinguish the other one but there are three lines total. You might want to check the vacuum switch located on the firewall near the wiper motor. there might be something wrong with the switch if the vacuum is not working.
Old 03-04-2005, 10:57 AM   #8 (permalink)
AE92-KrAyZiE!!!
PPW-546's Avatar
Flashmn, what cams are you using in our engine? I noticed that below 3000rpm, my engine runs okay but when it hits 3000 and up, the sound changes and it revs quicker. Is there a way for the rev speed to be consistent? I want to increase my bottom end rpm and take off faster.
Old 03-04-2005, 11:24 AM   #9 (permalink)
88 Corolla 4door
View albertmdh's Photo Gallery
revs being revolutions, rpms being revolutions per minute, anything above 3000 being more than anything less than 3000? is this that strange? sorry, smart-ass attack.
albertmdh is offline   Reply With Quote
Old 03-04-2005, 11:35 AM   #10 (permalink)
AE92-KrAyZiE!!!
PPW-546's Avatar
does VTEC ring a bell??????? soemthing like that... but i know it can't be possible since i'm running an outdated 5A motor, non-TVIS, no VVTi...
any ideas albert???
Old 03-04-2005, 11:51 AM   #11 (permalink)
Immortal
View Kwanza's Photo Gallery
any ideas albert???
Heheh... don't even bring up VTEC...
Umm, the engine picking up steam after 3000 rpms is NORMAL for most small stroke 4 cylinder gasoline engines. It hasn't much to do with anything but normal physics... Camshafts can modify how and where the engine makes its power... but don't expect it to be a completely different feel. Also... GE pistons will significantly increase compression when mated to an FE head.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 03-04-2005, 06:39 PM   #12 (permalink)
AE92-KrAyZiE!!!
PPW-546's Avatar
Excellent! Thanks for your help Kwanza. I guess i'll go with the GE pistons and some bigger cams. Would the GE cams work too or it only works for dual camgears?
Old 03-04-2005, 08:48 PM   #13 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
your gonna have way too much compression using ge pistons since the pistons are flat and the fe chamber is nearly flat, and nothing from the ge head will work in the fe head
Old 03-05-2005, 02:39 AM   #14 (permalink)
Resident asshole
Flashmn's Avatar
Like the man said. You might have problems with the G pistons and the totally different valve angles of the F head.
Old 03-08-2005, 12:36 PM   #15 (permalink)
AE92-KrAyZiE!!!
PPW-546's Avatar
i see. so what would be the best pistons for a stock block with ported head and angle valve job?
