Originally Posted by sonyman
What would I do if that were the case, and how do I check for that? I am getting the transmission fluid changed this week, which will hopefully fix this.
Scott
With the motor idling, lean on the valve cover in different spots putting a little bit of weight into it. If you hear a significant change in the vibration its a bad mount. Most likely it'll be the mount nearest to where you pushed when you heard the change.
Really all you need to do once you determine
if and which mount is broken is loosen the mounts, jack up the motor, secure it with jack stands (be sure to put pieces of wood between the jack/jack stands and the motor) and remove and replace the bad mount. Otherwise it can be fairly pricey to have one replaced by a shop.
