xrs computer swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2005, 04:52 PM   #1 (permalink)
View koggles_xrs's Photo Gallery
xrs computer swap
ok so heres the thing. my 05 xrs hits lift at about 6700 rpm and the 03 & 04 celicas hit it at 6000 and the 04 matrix hits it at around 6200. so my quest is to swap a computer from either a 04 matrix which i will probably try this week, or one from a 04 celica. if anyone has any any info or if anyone has tried or found a way to lower the lift point let me know.
koggles_xrs is offline   Reply With Quote
Old 03-13-2005, 06:41 PM   #2 (permalink)
Moderator
Gameroom cash: $571037
View silver04rollas's Photo Gallery
Not the 04 Matrix XRS. 04 XRS had the same 6650 rpm lift engagement as 05. The 03 Matrix XRS and all models of Celica GT-S hit lift at 6200 rpm, but I doubt it will increase any power since it will move the lift engagement at 6200 rpm and automatically would alter the flatter torque curve and reduce the torque at the low end (at 4400 rpm XRS puts out 118 wheel torque while GT-S is putting out around 103-104 ft lbs of wheel torque). Toyota had raised the lift engagement to accomodate more low end torque, but XRS's power climbs crazily in 300 rpm from 6650 rpm to 7000 rpm as seen in the dyn below that the graph is almost vertical during these 300 rpm, which is insane. Look at the dyno comparison of the XRS vs GT-S.
2005 Corolla XRS (left dyno with injen intake)
Peak Power: 162 whp and 118 ft lbs of torque (flatter torque curve with peak torque at 4400 rpm and 6800 rpm)
Lift: 6650 rpm
2000 Celica GT-S (right dyno with bone stock)
Peak Power: 151 whp and 111 ft lbs of torque (Torque peak at 6800 rpm and not as much torque below 6000 rpm)
Lift: 6200 rpm
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is online now   Reply With Quote
Old 03-13-2005, 07:01 PM   #3 (permalink)
the 04 matix i belive is tuned the same but i drove my buddys 04 xrs and ithits lift at 6200. unichip also makes a setup for that car.
Old 03-13-2005, 08:51 PM   #4 (permalink)
9THGEN GURU
View jcturbo's Photo Gallery
I would imagine since Lift is entirely dependent on Oil pressure, that there may be more to this than just the ECU. our oil pump may be a new design, to avoid past problem
jcturbo is offline   Reply With Quote
Old 03-14-2005, 12:52 AM   #5 (permalink)
View coogarxrs's Photo Gallery
that would be so sick if u could just change the oil temp pressure to engage lift at lower point
2005 indigo ink rolla xrs.
TRD axle back (in the mail)
Injen CAI (waiting)
coogarxrs is offline   Reply With Quote
Old 03-14-2005, 04:08 AM   #6 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Oil pressure is not what controls the lift, it's what activates it. The computer is what allows the oil pressure to activate it... the computer opens the valve that lets the oil in, basically.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 03-14-2005, 10:04 AM   #7 (permalink)
9THGEN GURU
but if the pressure isn't high enough, the computer wont activate it
Old 03-14-2005, 07:26 PM   #8 (permalink)
dont do it.the rolla xrs has more low end torque and ull lose that. someone at matrixowners.com tried and ended up losing 7whp when he tried replacing an 03 trix xrs ecu in his 04
Injen CAI (waiting)
Old 03-14-2005, 09:24 PM   #9 (permalink)
hmmmmmmm
my only other idea is to use a greddy e-manage to control lift. i emailed greddy yesterday to find out any info i can. an help would be great.
