ground problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2005, 08:16 AM   #1 (permalink)
View jimandee's Photo Gallery
Question brake lights and turn signal problem
when i push the brake pedal down the front and rear directional lights come on steady. It seems as if the passenger side comes on a split second before the drivers side. When i use the turn signal without applying the brakes the one selected will blink but the other side is just steady on and the same thing if i signal the other side. When the brakes are applied and the turn signal is used it barely blinks mostly steady. All the bulbs seem OK none that are black or with broken filaments. Any suggestions would be helpful. Thanks
jimandee is offline   Reply With Quote
Old 03-21-2005, 12:40 AM   #2 (permalink)
View paulandshoei's Photo Gallery
Start in the back... Your brake lights may be out, check your bulbs. Look at the wiring in the fixtures, behind the fixtures and under the car (or where ever they route the wires on that car). Typically its the bulbs, just replace them, they're relatively cheep.
paulandshoei is offline   Reply With Quote
