96 corolla burns aloy of oil "help" - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2005, 03:10 PM   #1 (permalink)
View bp34686's Photo Gallery
1996 corolla with 230 000 kms 0r 150000 miles burns 4 to 5 quarts per oil change. car has been dealer maintained. I checked the compression and every cylinder is between 70 - 80 psi. Removed the plugs and there is a heavy white build-up on them. The car is not leaking on the ground nor is there any smoke coming out the tail pipe at start-up on while driving. There is no residue on the dip stick nor in the radiator.
Is it bad valve seal, pcv valve or valve guides?
bp34686 is offline   Reply With Quote
Old 03-20-2005, 06:39 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
its wore out
Old 03-20-2005, 07:11 PM   #3 (permalink)
What are the PSI suppose to be for each cylinder.
Old 03-20-2005, 07:12 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
150, 160--------------------
Old 03-20-2005, 09:04 PM   #5 (permalink)
That seems high!
Old 03-20-2005, 09:12 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
nah, my moms 4afe pumps about 150 and burns no oil, 70 psi is about 4-1 compression ratio , you have to have 60 for it to even run right, the white stuff on the plugs is ashes, what oil are you using?
Old 03-20-2005, 10:26 PM   #7 (permalink)
5w30 bought at the Toyota dealer.
Old 03-20-2005, 10:32 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
wow, 5w, i guess where you are its ok, you could probably go to 10w without a problem?
Old 03-21-2005, 02:22 AM   #9 (permalink)
View 94_Rolla_Guy's Photo Gallery
i got a very similar problem mine is burning alot of oil too but it has like 170 - 180 psi compression my Haynes manual lists standard compression as 191psi and minimum compression as 142psi only having 70 - 80 it must run like sh*t maybe redo the compression test before assuming the worst, because i can't figure mine out either. Do you have any idea what your oil pressure is on average????????
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
