DIY - CORNER LAMP FLASHERS - Corolla FAQ addition
- 88le
Cut the ground wire for the parking light. Tape off the end that goes to the
car (you won't be using it anymore).
Splice the ground wire from the parking light (the bulb socket) to the alternating +12V
wire of the blinker. You'll need a piece of wire and some crimps to do this.
Parking lights off = parking light and blinker both blink at the same time.
Parking lights on = parking light and blinker blink alternately.
Remember to cut the ground wire on the parking light and only use the end that
goes to the bulb socket. Otherwise you'll end up with blown fuses. Also verify the wires with a DMM before you cut and splice.
Wires on a gen 2 (87 - 91) Camry
Ground wire on corner light = white wire with black stripe.
Alternating +12V wire on blinker = green wire with yellow stripe.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
