AE92 GTS short shifter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2005, 06:24 PM   #1 (permalink)
View browner's Photo Gallery
A friend of mine told me that the TRD Short shifter for the 88-91 Celica is the same as the 88-91 Corolla GTS/SR5. Is this true?
browner is offline   Reply With Quote
Old 03-25-2005, 01:09 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Just get the part numbers and see if they are the same. You could call a Toyota Dealer that is a TRD parts seller or posibly find the part number on an online store with TRD parts.
Chris Corolla S is offline   Reply With Quote
Old 03-26-2005, 01:44 PM   #3 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
Just make your own! like what i did!
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 03-26-2005, 03:23 PM   #4 (permalink)
View 89TCGTS's Photo Gallery
like trd dragon said.......just make it....i did it and its really easy..... just take a grinder, cut it on the straight part of it and cut an inch or 2 out of it, depending on how short you want it. then just weld it back together, and wah lah.....homemade short shifter.
89TCGTS is offline   Reply With Quote
Old 03-26-2005, 05:51 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That's the dumbest thing I've ever heard.. a short shifter is not called short shifter because its smaller... its called short shifter because the shifting time between gears is shorter than a regular shifter.
Old 03-26-2005, 07:03 PM   #6 (permalink)
Get Down Pro
View MistaSergio's Photo Gallery
wait wait wait, I haven't done a short shifter switch before but - if he thinks shorten it is a bad thing - does that mean theres more to the kit than just the rod? does it come with a new gear box? because that would make sense of him knocking the shorten stock rod - but if not then, I don't get why its an issue - doesn't it result in the same outcome?
I think I just confused myself, trying to say what I wanted to
What are YOU looking at?
Me-->> <<--You
MistaSergio is offline   Reply With Quote
Old 03-28-2005, 11:23 AM   #7 (permalink)
Guitars and Cars
If you cut the shifter it will have a shorter throw (with higher effort) and should make shifting a bit faster. Most after market "short shifters" both shorten the rod and raise the pivot point, to give a shorter throw without compromising as much effort. The TRD SS usually is almost the same leangth as stock but has a higher pivot point making the throw distance shorter by about 30%. Sometimes they come with new brakets, sometimes they don't.
Old 03-30-2005, 06:09 PM   #8 (permalink)
It's all about the shorter throw!! Everyone is on my case about how the shifter is long and looks like it belongs to a truck,i could care less about how long or what the shifter looks like i just want the throw to be shorter.TWM makes a short shifter(short throw)kit for 88 Celica so i need to find out if the Corolla GTS shifter is the same as the Celica.
Old 03-30-2005, 07:18 PM   #9 (permalink)
View automatic's Photo Gallery
Go to a junkyard and see if the GTS one is like Chris described in the previous post, with same length stalk, but less throw.
automatic is offline   Reply With Quote
Old 03-31-2005, 03:21 PM   #10 (permalink)
Guitars and Cars
2-second search reveals:
TRD makes an AE92 quick shifter:
http://www.trdracing.com/parts/00602-30301-005.htm
Do want to use the Celica one because you can get one cheap or something??
Just find a site that sells both parts and compare the part numbers like I said.
The Master Corolla Sticky has shitloads of product links, I'm not going to do it for you
