Need help asap. No start problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2002, 08:35 PM   #1 (permalink)
View kieran1094's Photo Gallery
After cleaning my engine yesterday on my 1986 Corolla LE A82, I drove it twice and it started right up both times at both ends of the trips. Then this morning it wouldn't start and the battery drained fast trying to start it. I only have a little trickle charger so I hooked it up and let it charge up. I also put 5 gallons of gas in since the gas guage is very erratic. So I cranked it some more and it still wouldn't start. Everything is turning over, just no start. It's dark out so I quit until tomorrow. I know to check for gas and spark, and I know I didn't smell gas in the carb as I was cranking it, so how do I test for gas flow. It has a mechanical fuel pump and I changed the fuel filter about a month ago. A couple of troubleshooting charts I looked at mentioned wet coil or cap or wires. Could it have started four times fine and then have a moisture problem? Any suggestions would be appreciated. I have a Chilton and a Haynes book. Thank you.
kieran1094 is offline   Reply With Quote
Old 07-28-2002, 10:01 PM   #2 (permalink)
Rolla Pat's Avatar
View Rolla Pat's Photo Gallery
mmmm...yes check for spark and gas. To check your pump, basically unloosen one of the banjo bolts from the filter and crank her, if it squirts out, it's fine, then check the carb. If not, then it's the pump.
Opinions are like assholes, everybody has one.
TOYODORI - The Quebec Toyota enthusiasts club - www.toyodori.com
Rolla Pat is offline   Reply With Quote
Old 07-28-2002, 10:48 PM   #3 (permalink)
View Deep's Photo Gallery
It could be moisture under the cap, but it would likely have evaporated overnight.
Deep is offline   Reply With Quote
