my cigarette light won't work!!!!!!!!!!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2005, 02:10 PM   #1 (permalink)
View area51's Photo Gallery
I'm not sure what the problem is. I pulled the fuse which says cig/radio and it's fine. It's a 20 amp one. Problem happened a while ago when I plugged in my fire fighter light and it worked for a few seconds then stopped. After that the cigarette lighter does not function, I have tried putting in the lighter and it always comes out cold. I haven't checked the fire light.. Any ideas?
1997 Toyota Corolla DX
area51 is offline   Reply With Quote
Old 03-25-2005, 06:38 PM   #2 (permalink)
foodaa's Avatar
View foodaa's Photo Gallery
You need a test light or DMM/DVOM to check if you're actually getting power/ground to the lighter socket. If you're not, make sure the fuse is really 'fine'. Get a wiring diagram.
foodaa is offline   Reply With Quote
Old 03-25-2005, 07:03 PM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Either that or check the wires.. you probably burnt one.
Old 03-26-2005, 03:20 PM   #4 (permalink)
View 89TCGTS's Photo Gallery
if none of that works and you can't figure it out you could just rewire it.....just run a prower from some source, get an inline fuse and hook it up to the positive on the lighter. then just gound it and you should be fine.
89TCGTS is offline   Reply With Quote
